Blasting Materials Question
Using a hopper gun to blast small pieces and brackets. Accidentally bought a 10 pound bag of US Minerals black diamond media but cant find any specific information on the use, damage possibility, or cleanup. Any advice would be appreciated, also recommendations for a media to remove paint, grime, and light rust.
I use black diamond media from Tractor Supply it's about 7-8 bucks for a 50lb bag. For interior and delicate parts I use their fine media 30/60 or ultra fine. For painted or rusty parts I use the medium 20/40. Always remove any grime, at least the best you can, before you blast. Also when blasting be sure to have a mask or respirator. You don't want to be breathing that crap in.
I also use the black diamond media from tractor supply. I run it through a Harbor Freight soda blasting tank. I had to switch out the brass ball valves with stainless steel ones because the black diamond would blast through the side of the brass valves in 30 seconds. I am happy with finish it leaves on the parts. Have used it on fenders, inner fenders, frame and various small parts. Ranger is right about the safety equipment. Do NOT blast with out it.
Interesting. I have been wondering the same thing and since we now have a few TSC's here in the Phoneix area finally maybe I need to run up the road to Wickenburg to check it out and grab some for the small parts. I have a small 20lb tank from HF and have been wanting to test it out but it is difficult to find clear direct info on media.
As noted, do not use sand, the silica can be very harmful, I use 'glass bead' and aluminum oxide. Initially started off w/ a media blaster but soon found regardless of the type of medium I used it would travel quite a distance; fortunately, I have understanding neighbors, can put a dull sheen on vehicle paint. Decided to go with a HF blasting cabinet, the type with a door on each side; thus, I was able to blast large items by sealing one side with a plastic bag. Came across a 'how to' article on hooking up the sandblaster to my cabinet; O Yea. Also found, in blasting the larger items, regardless of the type protection gear I used the medium would seek every orifice in the human body, made my life miserable for a few days. Now I just stick with the smaller items.
Try a few online supplier's they usually provide description on types of medium and use. Post link as example:
Most Popular Abrasives - TP Tools & Equipment
Suggest check directory for local supplier's, I was fortunate to come across an industrial sandblasting equipment and medium supplier relatively close and saved quite a bit on the cost of shipping.
John - NNY
10-31-2007 07:40 AM
