wiring glitch?
Old 03-22-2015, 09:34 AM
adamkat22's Avatar
adamkat22
adamkat22 is offline
wiring glitch?
I have an 85 E350 6.9 van. I just noticed that when I turn my left turn signal on, the left rear running light goes out. When the turn signal is not on, its fine. A while ago I had wired in for trailer lights. I don't think I noticed this problem at that point...but I guess I'm not sure. Anyone know what could be going on?
p.s. When I say 'running light' i'm referring to the rear lights that stay on all the time when you are driving with the lights on....
Old 03-22-2015, 09:40 AM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Usually those symptoms point to a bad ground.
Old 03-22-2015, 09:44 AM
adamkat22's Avatar
adamkat22
so i should look for ground connections somewhere in the wiring of the taillights?
Old 03-22-2015, 11:10 AM
tecgod13's Avatar
tecgod13
tecgod13 is online now
Yes.
Also wouldn't hurt to look at what they did when they added the trailer light harness.
Old 03-22-2015, 04:04 PM
Whatsinthebox's Avatar
Whatsinthebox
Whatsinthebox is offline
Possibly a wrong bulb. I have personally seen that cause problems.
Old 06-15-2015, 10:44 AM
adamkat22's Avatar
adamkat22
i'm only getting back to troubleshooting this after a long hiatus. i replaced the ground that is closest to the lights (the one I had wired in when i put the trailer light connector in). the other grounds near the taillights all seem solid.
i tried undoing the trailer lights. when i try putting the original brown wires together i get no light. when i add in the brown wire from the trailer light hook up i get light again...but still there is no light when i turn the left signal on.
not sure where to be looking next?
p.s. i also tried switching the bulbs as per the other suggestion, but that didn't fix it either...
Dirk O
11-18-2011 09:17 PM
houstone003
02-24-2011 04:17 AM
rebel_ford4x4
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-12-2006 10:32 PM
DitchDoctor304
1983 - 2012 Ranger & B-Series
08-22-2006 10:50 AM
jasontenter
11-15-2004 12:37 AM
Quick Reply: wiring glitch?
