Battery Problems - Need Help Diagnosing
Hello, I have a 77 F150 300 i6 and let the battery drain one night because I decided to be forgetful and leave the lights on. The next day I had the truck jumped and drove it around for a good hour or so. Within that hour I stopped at places and it would start up fine each time I fired her up.
Fast forward 4 or 5 days and I try to start her again, but the battery power is low again. She starts to crank but just barely, lights are dim, etc... The solenoid got stuck in the crank position and was cranking (very slowly) even when I had the keys out the ignition. I've heard that this happens when your battery power is too low.
Anyways, I jumped it again and drove it around 30 min. Later that day I tried starting it and it was dead again.
Should driving it around 30 min - 1 hour be enough to charge the battery? I'm wondering if I have a problem with my alternator and that this is going to slowly drain any battery I use.
Put the battery on a charger for 12 hours or more. That may work, or it may be time for a new battery. An hour of driving isn't enough for a full charge.
Also, check the voltage at the battery with a voltmeter, both running & not, & after you charge it.
Clean all the terminals, check the condition of the cables.
Alternators aren't really designed for completely discharged batteries, but just replacing the juice used to start the engine. A jump start will get things running, but the battery really needs a good thorough charging as soon as possible. The battery should be load tested, it may need to be replaced. A defective battery may ruin a good alternator, and the reverse is also true.
Thanks a lot everyone, shortly after I posted I went and got the battery checked and found out it was a dud. Had it replaced and things are working fine now. Good to know that the alternator is not meant for to recharging dead batteries, and that it takes longer than an hour of driving to recharge a battery. Thanks again for the info.
aviatorcal
02-23-2013 09:16 AM
79F-1504x4
53
03-03-2011 01:53 PM
mooktank
11-11-2002 03:18 PM
