Axle interchange and gearing questions
I have a 94 f150 4x4 (truck in sig) that I need to put 4.10's in to restore the gearing ratio back to stock performance after the lift that the P.O. put on it. I have been keeping an eye out for a complete rear axle from a junkyard. I found one at a local yard but they sold it out from under me by the time I got there . I have found a few others a state or two away but with shipping it would be cheaper to have my current axle regeared. Unfortunately regearing an axle myself and making sure it is all lined up and shimmed correctly is one of those things I don't feel comfortable doing myself.
So my questions are:
1. I was considering looking at the ford 9" rear axle that was offered in the 70's and early 80's trucks and see if I can find a 4.10 half ton axle. would one of these axles basically be a bolt in? I have access to a welder so changing spring perch positions would be easy. It is my understanding that the 9" is a stronger axle anyways, is this correct?
2. Would a f250 axle work with a bolt adapter kit? I have nice aftermarket wheels on my truck that I don't want to replace. I have a feeling that the f150 wheels don't have a big enough center hole to fit over a 250 axle hub. F250 and 350 rear axles in 4.10's are a dime a dozen around here though.
3. For the front axle I have heard that the f250 center will bolt directly into the f150 TTB and that they use the same shafts. Is this true? IF it is I could find a f250 front diff center easily and cheap and have a shop regear my rear and save money that way.
Here's a pic of the truck in question:
By the way, your sig says you have an extended cab, but the picture shows that it's a Ford. Ford calls them SuperCabs. Extended cab is a Ch*vy term.
on
In your case you need a rear axle VSS/RABS sensor for both your speedo and the PCM which also controls your auto transmission, so a 9" really isn't a good option. A 10.25 would bolt in and has the VSS but it has 8 bolt axles to so your wheels won't work. Unless you are doing a lot of hard muddin and build up the motor a lot it's not likely you will ever break an 8.8 so have yours regeared or find another with the right gearing to bolt in.
My SuperCab worked great when my boys were around 4. But by the time they were 12 and 14 I needed the crew cab. Now that they're off at college I'm hoping to add a SuperCab back into the stable, but I'm not planning on losing the crew (but you know what they say about plans...)
garthneddy posted this in a previous thread about gearing:
"Lightnings weren't the only F150s in this gen to come with factory 4.10s. I've owned a couple 4x4 F150s with them, 302 and 300 powered.
If replacing your front gears, you can always just pull a third member from a F250. It is very common to find 4.10s in the 3/4 tons and both the D44 and D50 will bolt onto you 1/2 tons axle beam and use the factory axle shafts."
Does anyone have personal experience with doing this?
I would talk to your local gear heads and see who they use for gear swaps.
Finding a lightning axle is not an easy task so putting 4.10s in would be MUCH easier. I just had my ranger axle (8.8) rebuilt for 600. 350 of that was labor, the rest was parts.
I can't help you on the front other than what garthneddy has posted
I think I will shoot garthneddy a pm and get some more info on the front.
