1991 F150 won't go into gear..?
Riddle me this. I let my cousin borrow my truck, when he brought it back he said "..something is wrong with it.." when i went out to go drive it home, the thing wouldn't go into gear. It's almost like it half engages. Put it into any gear, let the clutch out, and it grinds, and then pops out. What might this be?
Probably broken/worn-through shifter fork(s) - there are two. Very common failure point with this transmission.
You can leave the transmission in the vehicle and just remove the upper cover/shifter assembly from the cab. You'll see the cover held in place via ~10 bolts once you pull the carpet back.
Lots of info on this topic in here. Try a search under my ID and you'll find a few.
he's not gonna even ride in the poor old girl again. So you think I should pull apart the top of the trans and look and see if the shift forks are straight?
You can swap out the whole shifter/forks assembly as one unit or just replace an individual fork. Doing just one fork involves a little more work, but not a bad project.
But you're getting ahead of yourself. You need to figure out what the actual problem is first before deciding on a solution.
Ksanglem
332
02-23-2020 06:42 PM
cltrailer
01-07-2020 07:05 PM
rlberthi
08-01-2005 08:44 PM
idealtrucks
09-02-2004 04:40 AM
Forrest29
02-14-2003 07:26 PM
