Problem towing? need help
Hi guys hoping get some input on my 99 f250 with the 5.4L
Love the truck except when pulling a trailer .. I kno just 5.4 but even with a "lighter" trailer (maybe 4,000lbs) ill have it to floor and motor be screaming but barely moving from wat I have read so far the lil 5.4 should be doin better then wat mine is ...
on
Sounds to me like you have unrealistic expectations. You will be using wide-open-throttle frequently when towing something heavy, and there's nothing wrong with that. A larger engine would handle the load easier, but you're not hurting anything by putting your foot into it.
I don't think you have a problem. Your '99 is the only year that didn't get PI heads, so you are pushing all that weight down the road with only 235 HP. That's less than a modern minivan has, it's going to take some time getting up to speed.
I had an 06 5.4, which has more stock power, and felt the same way about that motor when towing. My trailers were definitely over 4k/lbs though. I think my rated max capacity was 9400lbs and I probably towed I the range of 5-7k. I felt that the motor had a "dead spot" between 2700-3500 rpms. It would make a lot of noise and not move(figuratively) until it passed 3500 rpms. This is for stop and go towing. I was towing around 7500-8000 on a highway ride that had lots of undulations and it was hard to keep it at speed and was constantly shifting. I just did not like the motor when towing or hauling.
I'm not sure what truck you have but looking at the towing guides for a 99 super cab 4x4 3.73 the max rating is 7400lbs. So 4k is over half the rated capacity. Anything higher and your closer to max which results in decreased performance.
http://hillerford.com/resource_library/RV_towing_guides/1999_towing_guide.pdf
You can put PI heads on your engine, that's a common thing to swap on some other vehicles that share these engines. You'd need heads and a new intake manifold.
