I'm going to assume the balancer is drilled center. There is more slop in the center than by the bolts holes. So if its centered with the pulley and that's a reasonable amount of slop, than I'm golden.
I measured it cause I had clearance issues with a couple bolt heads. 2 bolts fit with plenty of room, 2 didn't. I hade to clearance the inside of the pulley for the bolts to fit. If the bolt pattern was true the bolts should have fit. Like Gary said I didn't eye .0024, but I could definitely eye the slop in the center being more than the bolts holes.
I'm collecting parts for the lower end, so I don't have the balancer on the crank yet but interested to see when we get there. Like I said I had bolt clearance issues and when I measured, I found the pattern (on the pulley) to be off from center .0024 (yes 2.4 thousandths). I could have used different bolts, with a smaller head and it would have fit.
