Jump box or 3rd battery, hard start when hot ?
I had to call triple A today and get a jump because the truck would not start when hot, the truck lights right off with a jump when it does this. I had the batteries and charging system checked out last week and all is good but when the truck is hot it needs a jump or it will not start. STARTER???? I have had problems in past with weak starters. Is this common ?
Any input would be great and I was thinking should I keep a 3rd battery on the truck or invest in a jump box which would be better overall ?
Thanks!
Thanks!
How many have you replaced?
Make sure all your battery connections and the ground connections on the engine are clean and tight.
Starters, like all electric motors, don't like heat. While a hot engine is easier to spin and start, a hot starter has more resistance and takes more energy to spin.
Another battery/jump box only fixes the symptoms, not the actual problem. Much like putting on 3 coats will keep you warm driving down the highway in the winter, but closing the windows and turning on the heat is the real solution.
Take the screws out of the back cap of the starter, and replace with allen head bolts of the same length. The entire current the starter uses passes through the brushes, which are grounded through this plate, secured by those two screws. I went around in circles one this with my truck, finally replaced the screws with the allens, tightened them good and tight, and haven't had a single issue since.
I still have a spare starter that I may document this fix on once I get a bit of time.
Thanks a million.
I have had a hard time figuring a few issues with this truck. I finally found a IDI expert who is real reasonable to help with this rig in the future. He is a diesel mechanic and owns a 93 IDI turbo but he installed the Cummins six in it and runs it on all kinds of waste oil only.
What state is he in ?
Thanks a million.
