Lees build - repair - negleted maintenance finds - pic heavy
So I bought a 1997 F-350 7.3L Crew Cab Long Bed back in October of 2014 at a price I couldn't refuse... but should have!
I will update this first post with the list of things that I have done with dates... and include pictures as I get them in later posts.
11/01/14 - Front wheel bearing - slop
11/01/14 - oil change
11/01/14 - Tires - firestone
11/15/15 - weathertech vent shades
11/15/14 - Power steering box
11/15/14 - Power steering pump
11/15/14 - Pitman arm - couldn't be removed from box
11/15/14 - Belt
11/15/14 - Tensioner
11/30/15 - repaired mudflap mounts
11/30/14 - shocks
11/30/14 - Midship fuel tank - replace - leaking sending unit lock ring (rusted out)
11/30/14 - Exhaust - 4" MBRP Stainless with Muffler
11/30/14 - Tonneau Cover - Truxedo truxsport
11/30/14 - led tailgate light bar
02/15/15 - fuel filter change
03/15/15 - led third brake light
03/15/15 - led bulbs everywhere - dome, map, tail, brake, turns, running, park - note make sure you get the ones with resistors...had a full scale everything flashing with hazards (including roof clearence lights)...
03/15/15 - air cleaner upgrade - riffraff 6637
04/01/15 - Clear Headlight and turn lenses
04/10/15 - Transmission Rebuild flashing OD light - trans slip code
04/10/15 - guages - pyro, boost, fuel pressure, trans temp
04/10/15 - cb radio and antennas - uniden bearcat 880, firestik 4' black
04/10/15 - coolant flush - distilled water, prestone, and International DCA additive
04/10/15 - coolant filter added
04/10/15 - roof repairs (rust - previous owner siliconed holes and cab clearence lights)
04/10/15 - welded in steel to replace missing parts of core support
04/10/15 - turbo replacement - trashed compressor wheel
04/10/15 - diesel in valley
11/22/15 - turbo rebuild - failed....
05/02/16 - oil pan and water pump
06/24/16 - engine reinstall
10/30/16 - rusty bed replacement
10/30/16 Core support replacement
11/08/17 - Wiring work - gauges, CB, Pa Speaker
10/21/17 - Rear spring hangers, shackles and bushings
9/20/19 - new rear brakes
8/15/20 - new front tires
9/13/20 - new front brakes - greased wheel bearings
3/23/21 - carrier bearing and u-joint
