Park Light Dimension?
The lens is 5" wide by 2 3/4" up and down., The glass is curved on the bottom so both sides measure less then the center up and down. Reproduction lens available in clear or amber. The trim piece attaches with two screws directly to the bulb holder mounting bracket. The base mounting bracket is available as a reproduction. The trim pieces are available painted or polished stainless. Since the mounting bracket attaches to a painted gravel pan and the bracket is also the negative ground for the park light, you might need a separate ground wire between the bulb mounting bracket and the chassis/body.
