89 idi sudden lose of power
truck info 89 f250 5spd 200k new ip and injectors 2 years ago new fuel filter and now new lift pump
after installing a turbo from a 93 factory turbo(he rebuilt it) we took it for TEST run over a steep mountain drove great (best the truck ever drove he said) went got boost gauge ant what not but on the way back half way up the mountain within a sec the truck loss power hard, developed a bad rattle(sounds like one cylinder), and blew black smoke bad(but not rich coal).
got back to the shop and installed boost and cracked lines to help bleed. drove again same no power psi never went past 8 psi.
also after install the truck had a tick in the fuel line in the frame like the lift pump died and the ip was sucking fuel so we replaced the lift pump and blew out the fuel lines but no change but now it blows white smoke bad
Could the ip be failing? also we turned the ip 1 flat any help would be nice
White smoke can be caused by the ip. Just experience that on my 89, 5 months after ip had been rebuilt. advance piston went bad in the pump.
Just a couple things to check.
raw fuel also just talked to him the ticking in the fuel line went away with the new lift pump is it possible that the lift pump failed without notice awhile ago and over time the ip burnt up running on that solo? iv ran only on my ip when my 6.2 broke a fuel pump pushrod for 20+ miles nver hurt anything but who knows how long his ran on the ip
we gonna go put clear fuel line on right now to go check flow
we just put a clear hose on no air bubbles after a sec of running got on the phone with the injection company they told us to push that rocker arm in on the side of the pump ran way quieter and smoother and they told us its retards the timing so some how the pump advanced itself i dont think it skipped a tooth and if it woulda i think it would have caused a striped gear? anyone have this problem or know of this?
Edit: the truck didnt sputter at full throttle so its getting fuel i would guess
However, it is possible that the bolts holding the IP to the cover somehow loosened and the pump rotated a bit changing its timing. Thats highly unlikely to have just randomly happened, and would most likely cause other issues as I don't think it could just move and stay in that new position.
You mentioned cracking the injector lines to bleed the air. Did you crack them one at a time AFTER the engine had been running for a while and all the air should have been bled from the lines?
To elaborate on what was said, you want the engine running /normally/ when you want to evaluate how the engine runs and the difference in sounds. So make sure its been run for a few minutes to clear any air that might have been in the lines from when you had put in the clear line or whatever else. If you loosen one line at a time, it effectively shuts down just that one injector. Each line should make the same difference when loosened, that the engine looses a bit of power. If its NOT the same for each line, note the one thats different than the rest. Either it will make no difference at all when loosened, or a bigger difference than the others. That would pinpoint that one injector, or cylinder having an issue.
Received 3,102 Likes
on
he ended up calling moose pumps and decided the ip advance plunger died so hes ordering a moose pump. Southern Oregon fuel injection keep giving us the run around for help so he called moose and was very helpful. i just bought a Oregon pump wish i hadnt wish i would went for moose but i hope mine last more than 2 yrs thx everyone
yes and their very nice and detailed bout there product
when i ordered my ip and injectors and return line from southern oregon i told them i had a turbo a thousand times and 1. forgot to turn my ip 1 flat at their shop so i did 2. sent me the wrong return line (the return cap with only 1 plug) and charged me more for them to send it out
Moose was very nice my brother said and got a pump built and sent asap cause its hes daily
