Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
brain Flatulence; put gas in diesel tank
Old 03-19-2015, 08:04 AM
scarsbeattats's Avatar
scarsbeattats scarsbeattats is offline
scarsbeattats is starting off with a positive reputation.
Well, almost. I was towing an 18' X 8' dual axle full of my daughter's life from NC to the big apple and I had to use the restroom. I pulled into the gas station, swiped the card, and inserted the "green" nozzle into the tank, said to her, "here fillerup", and double timed it to the rr.
I came back and she said; "Dad, this didn't look right so I didn't pump it." The green was one of three, BUT it was just 93 octane gasoline, wtf.
GREAT KID and smart as all get out!
I read on another forum that I frequent, about modern muskets, that another guy had done this and his friend, a mechanic, told him to add 2 qts of ATF and one of 30 weight in the tank and good to go.
Is there any validity to this?
Are there other recipes?
SEMPERPARATUS MOLON LABE & two is one; one is none
Old 03-20-2015, 08:34 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Happened to me during the rally in Sturgis. They were changing the pump to unleaded, but it still read Diesel. Anyway about thirty miles later starts running rough and pumping out white smoke. Called the mechanic from a friends house. Said drain the tank and the fuel bowl. Added two cans of Sea Foam and another lubricant and filled back up with Diesel. Was lucky, no issues...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
Similar Threads
brain Flatulence; put gas in diesel tank scarsbeattats General Diesel Discussion 5 03-19-2015 01:15 PM
Rim Sema f100swe 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-04-2014 07:26 PM
gas n diesel tank..... 94 Turbo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 02-07-2009 10:56 AM
many hood assembly ?'s 52' w/inline-6 52'F-3 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-04-2008 03:55 PM
Ford Ranger Tonneau Cover bobsevern Ranger & B-Series 0 05-01-2005 12:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
