Tomahawk's Highboy Thread
#212
Received 3,555 Likes
on
#213
#214
#216
Received 3,991 Likes
on
#217
I meant in those old commercials Maytag referenced that there was Maytag repairmen, but they were "Never Needed". Like an inspector checking Gavin. Remember how they portrayed the repairman as being bored?
#218
on
Yes, Gavin is harder on himself than any inspector would be.....
#220
on
#221
#222
on
#224
Not much progress to report but I did get a lot of little details completed. I got all of the compressor lines run, bled the brakes and checked for leaks, added more cable ties to the wiring harnesses......
I made a blue lens out of screwdriver handle. I'm using the old brake warning light as an indicator light when I have the compressor switched on.
I wish it was a little darker blue but it will work.
I made some plugs for the axle vent hoses.
The instrument cluster is now completely hooked up.
The switch to the right of the steering column, where the choke was, is for the inverter. It's indicator is the red light on the vacuum gauge. The switch to the left of the steering column, where the wiper switch was, is now the air compressor toggle switch.
Now I need to get started on the exhaust. I may try to start it this weekend.
#225
