Transfer case broke in half. 2000 excursion v10
Old 03-18-2015, 09:24 AM
dudly426's Avatar
dudly426
dudly426 is offline
Having problems. Transfer case broke in half, I think it is because of the auto free wheeling hubs. Is it possible to manual hubs on it?
Old 03-18-2015, 09:28 AM
Vince79vette's Avatar
Vince79vette
Vince79vette is offline
Dam man really. Figured the factory hubs would give out first. And ya u can use mile marker ss hubs or warn premium hubs both are Manuel
Old 03-18-2015, 09:29 AM
ExploringNH's Avatar
ExploringNH
ExploringNH is offline
To answer your question, yes, you can put manual hubs on it. I run Warn Premiums. Yukon has some nice ones. There are plenty of options out there.
To address your problem, your hubs did not cause your transfer case to break in half. You have a problem somewhere.
Old 03-18-2015, 12:15 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
I have read elsewhere in the superduty world that runnng with hubs engaged all the time can contribute to this exploding transfer case thing. You are not the only superduty to have one blow apart. I don't believe one way or the other as it hasn't happened to me. I have not heard a definitive cause yet, but ford switched fluids in them at one point.
also, if you change your thread title to "my transfer case broke in half" then add some pictures for us to jaw drop at, you will get a much larger response. Oh and I almost forgot; Welcome to the forums!
Old 03-19-2015, 07:01 AM
dudly426's Avatar
dudly426
dudly426 is offline
here is the picture still in the truck
Any ideas on where I should look to find the problem?
Old 03-19-2015, 07:54 AM
NCTunanut's Avatar
NCTunanut
NCTunanut is offline
Dang, that's broke. Sorry for your loss. Before I replace the transfer case, I'd find out for sure what caused that.
Old 03-19-2015, 07:59 AM
05MilMachine
Well.. Some have suggested that the tcase possibly tried to shift into 4low uncommanded while driving. Others suggest the fluid is to blame by making the aluminum weak. Most just change the broken case and move on. Hopefully that's your only issue. I would replace the tcase, replace all ujoints and have the driveshafts checked for issues, then switch to manual hubs and you should hopefully be good to go.
oh yeah, and make sure your engine mounts, trans mounts etc are good. One of those being broken can stress things as I have broken tailshaft housings on AOD trans before due to bad engine mount allowing movement. Just something else to check.
Old 03-19-2015, 08:28 AM
Vince79vette
Dammm. It did break in half. Thats nuts man. If they do switch randomly to 4wd low, manual hubs i think would be the fix
Old 03-19-2015, 09:45 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
***Insert run of the mill "that'll buff out"/duct tape/JB Weld joke here***
Old 03-19-2015, 10:13 AM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
Jihadi squirrels? Damn if that isn't broke though.
Old 03-21-2015, 01:30 AM
AppocAlexx's Avatar
AppocAlexx
AppocAlexx is offline
Have you been able to take this off and open it up to see what it looks like on the inside that will be able to tell you a lot of where the prolem might be, i will be following this one for future references. Good luck. Look forward to updates and more pics.
Old 03-21-2015, 02:34 AM
ford_model'a''s Avatar
ford_model'a'
ford_model'a' is offline
Wow, that's a catastrophic fail. If I may ask, how many miles on the truck?
74FordCrewCab1stimer
03-03-2014 07:54 AM
DieselVol
1999 to 2016 Super Duty
07-01-2012 11:18 PM
juchertf100
10-15-2009 08:47 AM
danimal
02-02-2003 10:31 PM
dan18156
01-27-2001 06:17 PM
Quick Reply: Transfer case broke in half. 2000 excursion v10
