97 explorer starting problem help please
So I have a 97 ford explorer 4l v6 it turns over and starts on occasion but not so much lately. I have changed the fuel filter spark plugs coil pack o2 sensor and air filter in hopes of some miracle of a fix but still no go and another day of work is falling away please help
Welcome to the forum!
Have you made any attempt to determine what you don't have when the engine won't start? Do you have a way to confirm whether or not you have spark and/or fuel pressure?
There are several different things that could cause a no start. Understanding if you have good spark and good fuel pressure when the truck won't start will go a long way in narrowing down the list of possible causes.
-Rod
-Rod
Check your fuel pump relay and your Ecm relay. I had problems with both of mine. And that would cause intermittent starting. It even shut down on the highway twice. But after I changed both of those relays never had any more problems.
Can you hear the fuel pump relay clicking and the pump running?
TroubledExplorer
02-18-2018 06:24 PM
obh
06-03-2014 11:18 PM
trplad
13
03-15-2012 03:23 PM
Explorer180
03-15-2011 10:32 PM
