97 explorer starting problem help please
Old 03-18-2015, 08:22 AM
uzaki474's Avatar
uzaki474
uzaki474 is offline
So I have a 97 ford explorer 4l v6 it turns over and starts on occasion but not so much lately. I have changed the fuel filter spark plugs coil pack o2 sensor and air filter in hopes of some miracle of a fix but still no go and another day of work is falling away please help
Old 03-19-2015, 07:04 AM
shorod's Avatar
shorod
shorod is offline
Welcome to the forum!
Have you made any attempt to determine what you don't have when the engine won't start? Do you have a way to confirm whether or not you have spark and/or fuel pressure?
There are several different things that could cause a no start. Understanding if you have good spark and good fuel pressure when the truck won't start will go a long way in narrowing down the list of possible causes.
-Rod
Old 03-25-2015, 08:19 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Or you can just sit back and wait for the miracle..
... Philip
Old 03-26-2015, 06:50 PM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
What about checking for codes?
Pull a plug or two and have a look. See if it is getting fuel.
You can also check for spark
Old 03-28-2015, 12:11 PM
magrahamkp08's Avatar
magrahamkp08
magrahamkp08 is offline
Check your fuel pump relay and your Ecm relay. I had problems with both of mine. And that would cause intermittent starting. It even shut down on the highway twice. But after I changed both of those relays never had any more problems.
Can you hear the fuel pump relay clicking and the pump running?
Old 03-28-2015, 01:56 PM
aquanaut20's Avatar
aquanaut20
just for laughs..
Check the connection for the Crank sensor, front, passenger side of engine..
Corrodes and causes your fault...
... Philip
TroubledExplorer
02-18-2018 06:24 PM
Ehayes
07-09-2016 05:05 PM
obh
06-03-2014 11:18 PM
trplad
13
03-15-2012 03:23 PM
Explorer180
03-15-2011 10:32 PM
Quick Reply: 97 explorer starting problem help please
