low on power at high rpm
i bought a new to me truck selling my 00 with an 01 motor ext cab auto and getting a 01 crew lb mt.
i bought the truck with 220 on it and the poppet valves were worn to .001 and 1 injector was 0 or close to it. 2 reman injectors, the truck was completely stock and i bought it from the original owner. i got it shimmed the injectors with .002 shims from mcmaster carr. straight piped it, 6637 air filter, new luke ceramic clutch, original owner had a new bosch hpop, turbo center section (the compressor wheel seems to have some dusting on it), and injector orings 50,000 miles ago, and dp tuner with the 140 hp aggressive tune. i have talked with jody (great customer service) and have decided to step down to the 80 tow tune with some throttle adjustments, and sealed up all ext. leaks.
my old truck with a k&n, 4" exh., and juice with attitude on 37's had allot more pulling power i hooked my crawler up to it this last weekend and headed to the coast, a hill i could usually gain speed up to 10-15 mph in a 3-400 yrd stretch with my old truck i could barely stay the same speed with my new truck on stock tires. my fuel pressure drops to 54 lbs at wot, my ebp sensor reads around 50 at wot, im hitting 30-32psi of boost (old truck was 25psi max), the on thing i see limiting power is the icp hits 1200psi max - 85% ipr on a wot hpop test run (stock will hold 3200psi - 32% ipr). this is why im going to the 80 hp tow tune. my old truck would only hold 900psi??? it seems that once i go over 10psi of boost it does not feel like it pulls any harder from 10-30psi, and once i hit 2200 rpm it will not pull any harder (kinda acting like a cummins, all the power is down low) im kinda lost as to why it is not pulling harder than my old truck. and would like to find out why i dont have more power, it s driving me up a wall.
sorry for the long story, and jumbled mess i have. any help is greatly appreciated. i can get any readings you need on the truck just let me know
Rebuilt HPOP's like your Bosch have a reputation of not working out too well long term. We've seen many failures where they would build acceptable pressure while cranking, but weren't able to provide enough flow. Seems like I recall one with a no start condition that could build around 3,000 psi while cranking, but if you disconnected the HPOP hose while cranking oil would only dribble out.
Obviously your best bet is to find someone close by with the same motor that would let you swap HPOP's for some test runs. Otherwise it's a $$$ gamble that you get to take.
If you decide to replace it, I'd suggest one of the reputable aftermarket suppliers that offer increased performance over the stock application. Not necessarily for the increased performance, but because they have a better track record than the parts store rebuilt units.
I did some testing on the way to work. I don't like doing this but oh well, I didn't let warm up this morning and got on it 3 min after initial start up, usually these have slightly less power with the ebpv closing which I could hear mine starting to close. My oil psi never fell below 1800 and it pulled allot harder than normal about like my old truck. So I think I will get the 80t put on the chip and bump it back up to the 120tune after the t500 gets put in.
You can go through the settings in Torque Pro to set up logging for each PID you monitor. Once you have a log, you can share it here - but there's a process to go through to get the data across the forum.
How does the truck do with a stock tune? What happens if you have the 80 or 120 tune in place and you give it about 2/3 throttle instead of going to the floor?
By the way... stock injectors only have a 60-65 HP reserve above stock HP. A 60 or 65 HP tune would not need modifications to the truck to get that bump.
I only have a single tune, I don't want a ****, for the simple fact my old truck the chip was set on extreme with the low boost fueling on high. I never touched it. I was on the 140 HP aggressive tune stock I hold 3300 psi or around there at wot. Its in the 3000 psi range no lower, With 35-40% ipr. I talked with Jody a couple weeks ago and need to send my chip back for mods no matter what, but he's damanding icp at 3200psi wot. In that tune. I will try to figure out data longing tonight. What pid's would you like me to moniter besides rpm, ICP, IPR, ebp, inj. Pw?
Im confused now - it's easy to do......
What tune were you running this morning? What was the ICP & DC like?
If you could datalog:
ICP
Duty cycle %
Fuel Inj Pulse width
Mass fuel desired
Speed (MPH)
A good run from 55-90 mph, roll the throttle & don't let her downshift .
If you can remember in the morning, before you start your truck:
look at your Baro sensor, Manifold Air Press & Exhaust back press sensors. All should be within .2-.4 psi of each other.
Tugly might chime in to add a couple of more parameters to watch - 😎
ICP
Duty cycle %
Mass fuel desired
Speed (MPH)
ok figured it out just got back from a run. if i barrely give the truck throttle (1/8-1/4) it will pull much harder than wot. as soon as i get past a certain point it feels like an anchor is thrown out behind me and the truck doesn't want to climb freely in rpm.
rpm ipr icp mfd pw mph
1412.25 30.93 2374.05 0 600 47.85
1354.5 30.93 2374.05 6.19 1672 47.85
1354.5 30.93 2694.96 6.19 1672 47.85
1354.5 33.63 2694.96 21.06 1672 47.85
1416 33.63 2694.96 21.06 2376 48.47
1416 29.38 2736 21.06 2376 48.47
1416 29.38 2736 21.06 2432 48.47
1446 29.38 2736 21.06 2432 49.09
1446 27.45 2554.17 21.06 2432 49.09
1470.5 27.45 2554.17 24.62 2696 49.09
1470.5 27.45 2219.01 24.62 2696 50.33
1470.5 31.31 2219.01 39.44 4232 50.33
1495 31.31 2219.01 39.44 4232 50.95
1495 41.36 1366.29 39.44 4232 50.95
1495 41.36 1366.29 76.38 6472 50.95
1532.25 41.36 1366.29 76.38 6472 52.2
1532.25 47.93 1018.02 76.38 6472 52.2
1567 47.93 1018.02 90.25 6536 52.2
1567 47.93 1009.47 90.25 6536 52.82
1567 55.28 1009.47 91.62 6536 52.82
1596.25 55.28 1009.47 91.62 6552 52.82
1596.25 55.28 1008.9 91.62 6552 54.68
1596.25 62.62 1008.9 91.88 6552 54.68
1633 62.62 1008.9 91.88 6552 55.3
1633 69.58 1006.62 91.88 6552 55.3
1633 69.58 1006.62 92.25 6568 55.3
1668 69.58 1006.62 92.25 6568 57.17
1668 76.54 1027.71 92.25 6568 57.17
1706 76.54 1027.71 92.38 6576 57.17
1706 76.54 1038.54 92.38 6576 57.79
1706 83.5 1038.54 92.56 6576 57.79
1752.25 83.5 1038.54 92.56 6560 59.65
1752.25 83.89 1020.87 92.56 6560 59.65
1752.25 83.89 1020.87 92.81 6568 59.65
1788 83.89 1020.87 92.81 6568 60.27
1788 83.89 1039.68 92.81 6568 60.27
1806.25 83.89 1039.68 92.88 6576 60.27
1806.25 83.89 1015.17 92.88 6576 61.52
1806.25 83.89 1015.17 93.12 6576 61.52
1848 83.89 1015.17 93.12 6584 62.76
1848 83.89 1032.27 93.12 6584 62.76
1848 83.89 1032.27 93.44 6600 62.76
1899.5 83.89 1032.27 93.44 6600 64.62
1899.5 83.89 1020.3 93.44 6600 64.62
1921 83.89 1020.3 93.62 6608 64.62
1921 83.89 1016.88 93.62 6608 65.24
1921 83.89 1016.88 93.88 6608 65.24
1965.25 83.89 1016.88 93.88 6600 65.24
1965.25 83.89 1036.83 93.88 6600 66.49
1965.25 83.89 1036.83 93.94 6600 66.49
1989.25 83.89 1036.83 93.94 6592 67.73
1989.25 83.89 1037.97 93.94 6592 67.73
1989.25 83.89 1037.97 94.25 6600 67.73
2011.5 83.89 1037.97 94.25 6600 68.35
2011.5 83.89 1018.02 94.25 6600 68.35
2055.75 83.89 1018.02 94.38 6600 68.35
2055.75 83.89 1026.57 94.38 6600 69.59
2055.75 83.89 1026.57 94.5 6600 69.59
2086.5 83.89 1026.57 94.5 6600 70.21
2086.5 83.89 1022.01 94.5 6600 70.21
2086.5 83.89 1022.01 94.56 6608 70.21
2114.75 83.89 1022.01 94.56 6608 71.46
2114.75 83.89 1031.7 94.69 6608 71.46
2134.25 83.89 1031.7 94.69 6600 71.46
2134.25 83.89 1016.31 94.69 6600 72.7
2134.25 83.89 1016.31 94.81 6592 72.7
2158.75 83.89 1016.31 94.81 6592 73.32
2158.75 83.89 1017.45 94.81 6592 73.32
2158.75 83.89 1017.45 94.94 6600 73.32
2165 83.89 1017.45 94.94 6600 73.94
2165 83.89 1022.58 94.94 6600 73.94
2165 83.89 1022.58 95 6584 73.94
2226.75 83.89 1022.58 95 6584 75.19
2226.75 83.89 1019.16 95 6584 75.19
2241.25 83.89 1019.16 95.06 6592 75.19
2241.25 83.89 1002.06 95.06 6592 75.19
2241.25 83.89 1002.06 95.25 6592 75.19
2253.5 83.89 1002.06 95.25 6528 76.43
2253.5 83.89 1035.12 95.25 6528 76.43
2253.5 83.89 1035.12 95.38 6472 76.43
2283.5 83.89 1035.12 95.38 6472 77.05
2283.5 83.89 1031.13 95.38 6472 77.05
2283.5 83.89 1031.13 95.38 6360 77.05
2285 83.89 1031.13 95.38 6360 77.67
2285 83.89 1028.85 95.38 6360 77.67
2324.75 83.89 1028.85 95.5 6360 77.67
2324.75 83.89 1040.25 95.5 6360 78.29
2346.5 83.89 1040.25 95.5 6304 78.91
2346.5 83.89 1048.8 95.5 6304 78.91
2346.5 83.89 1048.8 95.62 6256 78.91
2345 83.89 1048.8 95.62 6256 80.16
2345 83.89 1061.91 95.62 6256 80.16
2345 83.89 1061.91 95.62 6208 80.16
2361.25 83.89 1061.91 95.62 6208 80.16
2361.25 83.89 1033.41 95.62 6208 80.16
2380.75 83.89 1033.41 95.75 6168 80.16
2380.75 83.89 1049.37 95.75 6168 80.16
2380.75 83.89 1049.37 95.88 6168 80.16
2397.5 83.89 1049.37 95.88 6112 81.4
2397.5 83.89 1060.77 95.88 6112 81.4
2397.5 83.89 1060.77 95.94 6112 81.4
2423.75 83.89 1060.77 95.94 6072 82.02
2423.75 83.89 1057.35 95.94 6072 82.02
2423.75 83.89 1057.35 96 6032 82.02
2441.25 83.89 1057.35 96 6032 82.64
2441.25 83.89 1080.72 96 6032 82.64
2465.25 83.89 1080.72 96.06 5984 82.64
2465.25 83.89 1076.73 96.06 5984 82.64
2465.25 83.89 1076.73 96.12 5976 82.64
2483.25 83.89 1076.73 96.12 5976 83.26
2483.25 83.89 1087.56 96.12 5976 83.26
2483.25 83.89 1087.56 96.12 5888 83.26
2485 83.89 1087.56 96.12 5888 84.51
2485 83.89 1091.55 96.12 5888 84.51
2485 83.89 1091.55 96.31 5888 84.51
2478.25 83.89 1091.55 96.31 5880 84.51
2478.25 83.89 1091.55 96.31 5880 85.13
2478.25 83.89 1107.51 96.31 5880 85.13
2478.25 83.89 1107.51 96.38 5832 85.13
2509.75 83.89 1107.51 96.38 5832 85.13
2509.75 83.89 1113.21 96.38 5832 85.13
2509.75 83.89 1113.21 96.38 5768 85.13
2542.25 83.89 1113.21 96.38 5768 86.37
2542.25 83.89 1108.65 96.38 5768 86.37
2542.25 83.89 1108.65 96.5 5768 86.37
2550.75 83.89 1108.65 96.5 5752 86.37
2550.75 83.89 1114.35 96.5 5752 86.37
2550.75 83.89 1114.35 96.44 5752 86.37
2561.25 83.89 1114.35 96.44 5712 86.37
2561.25 83.89 1122.33 96.44 5712 87.61
2552.5 83.89 1122.33 96.5 5712 87.61
2552.5 83.89 1130.31 96.5 5712 87.61
2552.5 83.89 1130.31 96.56 5712 87.61
2596.75 83.89 1130.31 96.56 5624 87.61
2596.75 83.89 1133.16 96.56 5624 87.61
2620.25 83.89 1133.16 96.62 5624 87.61
2620.25 83.89 1133.16 96.62 5624 88.23
2620.25 69.97 1172.49 0 5624 88.23
2604 69.97 1172.49 0 600 88.23
2604 69.97 1172.49 0 600 87.61
2604 56.05 2533.08 0 600 87.61
