why won't code scanner light up
Get's tougher and tougher trying to help these new guys who don't even leave the smallest bits of info other than "don't work---what now?"
more info for non psychics
Sorry,I'm lucky I even figured out how to post thread. F150 with 5.4 engine just abruptly quit one 15 deg below 0 day.no stutter or sputter or anything.cannot here fuel pump. All lights work.everything but scanner and 1 socket of dual outlet that has not worked for a while.battery is a real good one,not more than 1 year old. Could have missed blown fuse,wouldn't be the first time.plenty of gas.introduced gas to throttle body, nothin.jacked up truck and stuck ear on tank while the woman ran switch, nothin.every thing beside engine works.very strange.mm
New Memeber Same Problem
I justexperienced the same problem with mine today...scanner could not read because fuse was blown...not sure what year truck you have but I have a 2003...check the fuse box located to the left of the bottom steering wheel...check fuse 3 to see if it is blown...if so replace it with a 20 ATM of course and try again...hoe this helps you.
Mike
Mike
