Alignmetn issues on 2005 F250 4x4
I originally posted this on the SuperDuty forum...without much response. Hoping for more here.
I've seen this topic come up a few times but I have not found the answer that is applicable to my situation.
I'm the original owner. I have had some sort of alignment issue since new. My current symptoms are:
- wearing of outer passenger front tire.
- drift to the right. Have to hold the wheel at 11 o'clock to keep straight.
Maintenance performed:
- new upper/lower ball joints, tie rods, drag link 25K ago. (motorcraft parts)
I bought lifetime alignment from Firestone. I went in over the weekend. They performed alignment check but found it within spec. They also looked for an worn components. None found. Both front tire were down a few lbs.(65Psi). I rotate and re-balance every 4K. Tires have about 6K on them (Michelin LTX M/S 2). I also have dual steering stabilizers installed. Any recommendations of where to look or adjust that could be causing this continuing issue? Thanks in advance for y'alls help.
__________________
__________________
Stone Mathews
1999 to 2016 Super Duty
05-19-2008 03:14 PM
