Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1978 f600 wiring harness
Old 03-08-2015, 01:38 PM
Bobird's Avatar
Bobird
Bobird is offline
I recently stripped out my cab in preparation for paint. I saved and labeled my old harness. I'm looking for a replacement because it's been diced and spliced a lot over the past 36 years. Does anyone know of a replacement for the f600??
Old 03-17-2015, 03:35 PM
FBNengr's Avatar
FBNengr
FBNengr is offline
Smile
Hey Bobird,
You probably ain't gonna' find an N.O.S. F-600 wiring harness on some dusty old warehouse shelf somewhere (although stranger things have happened).
Good thing you saved and labeled your old harness. Probably only a couple of possibilities now. You may be able to find a wiring harness for a '67 ~ '72 light-duty F-series pickup where you might possibly be able to utilize part or most of the harness. FYI, the '73~'79 F-600 dashboards are most similar to the '68~'70 light-duty F-series pickup trucks, so I'm fairly confident the the wiring requirements will be very similar. LMC Truck in Lenexa, KS might have such harnesses, maybe some other outfits too. Probably not cheap no matter where you find them.
Or, you will simply need to dig in, strip out and replace your diced-up wires one at a time, from where they start to where they end.
Good luck on whatever you come up with.
Old 03-17-2015, 11:52 PM
Bobird's Avatar
Bobird
Bobird is offline
Believe it or not first phone call netted me a stock replacement! I called Chuck of Chucks Trucks. He dug around a little and called back with a N.O.S harness. He was as surprised as I and probably now you! Not cheap but by far the best alternative!
Thanks for your help!
77_150
19
08-08-2013 09:26 PM
KSRedsoxFan
06-24-2010 06:55 PM
86bigred
05-05-2009 08:28 PM
louisianman
18
05-31-2007 01:14 PM
papa's 64
03-05-2005 04:08 PM
Quick Reply: 1978 f600 wiring harness
