HORRIBLE camber
HORRIBLE camber
97 F250 4x4
New upper and lower ball joints, inner and outer tie rod ends and drag link, all replaced in the last 7 months.
I did the tie rods about a month ago but have not bothered to get it aligned (tracks fairly well, was meticulous with measurements), because with such a horrible positive camber, I figured an alignment shop wouldn't be able to get anything done the way it is.
Driving forward, camber is WAY positive, degree wise, I'm not sure. Had new tires put on when I bought the truck a little over a year ago, outside tread is damn smooth. When I back into a spot, tires seem to straighten out to damn near perfect. The positive camber is very noticeable.
What should I check? I'm fairly new when it comes to front end suspension past ball joints and tie rods.
I'll look into that, thank you.
Question, for my own understanding. How do those two things affect camber? How could shackles (aka leaf springs??) give such a bad camber? Tires look like this from the front \ /
Not questioning your answer, I'm just trying to understand the terminology for the front end because it seems there are various names for the same part. May have to barnify it for me.
The TTB front end has some personality quirks.
Changing the spring bushings and the center pivot bushings to new, or better yet, polyurethane, will help. Make sure you pull the front spring 'shackle' from the frame to change both ends of it. It is a surprisingly small bushing and is likely in very sad shape.
Camber is changing because you have some toe in. As you roll forward the wheels steering into each other causes the bottom of the tires to try to get closer, tilting the top of the wheel out. Roll backwards, the top tilts in. Some of the tilt is from the slop in the spring and pivot bushings, ball joints and the wheel bearings, some of the tilt is the tire itself deflecting.
When I backed into a parking space my tires went like this: / \ When driving forward the looked about straighter: | | This is about normal for the TTB front end. I quit backing into parking spots.
The truck has to be aligned with the front tires 'loaded' in the rolling forward condition. Yours seems to be opposite.
If you are doing the work, roll the truck backwards as far as practical, then roll it forward to your work spot. Makes some adjustments, then roll it back and then forward again. Keep doing it until it is correct rolling forward. Unless you are doing a lot of crash derby driving, forward is your primary direction anyway.
And if you are taking it to an alignment shop, chat with them about this before they put it on the rack. If they don't seem to understand, you may want to go to another shop.
Received 3,103 Likes
on
agreed. when i do front alignment on a TTB vehicle, i drive it in off the road and stop. no reversing at all before i mess with the front end.
people always freak out when they see the front wheels all out of whack after backing it into a spot. but they understand once i explain how the TTB works and move it forward 25 FT and it sits properly.
My experience with this.... hope it helps
Wezo, the front leafs on my '97 were so shot that I was on the bump stops. My wheels looked like this / \ all the time.... worse when I backed up. I had my buddy who is an ironworks blacksmith, re-arc them. We replaced both front and rear bushings.
At the finish, the truck sat a little too high in front. Now looked like this \ / .
We had to take some arc out of them to get it right. That's the quirks of this TTB front ends. Maybe you have too much spring up front.... may want to check that out.
??????? My '89 F150 and '91 Bronco did that stuff when brand new. 'Coures got way worse as it aged. In fact I see 9 of 10 do the same thing. Almost every TTB Ford of this era do that, especially backing up. I'll post a vid from the campsite this summer.
I'm sure most people know, that the sleeve at the top ball joint is removable so it can be replaced, changing the caster and/or camber.
There is also an adjustable sleeve too so that you don't have to keep buying new sleeves.
The challenge is finding an alignment shop that knows how to do any of this...
Just saying how it is with mine. And I still stand by what i said. IF the D50 is right, its fine. I back mine in everytime I park it. Never had a problem.
Timberwolf13
15
03-30-2014 10:42 AM
akjw7
10-17-2011 03:11 PM
