Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
AlternaYor problems!!
Old 03-16-2015, 05:57 PM
Jerdina53's Avatar
Jerdina53
Jerdina53 is offline
alternator has been replaced two times allready and the second time they it was repl. Right after battery light came on started flickering and it will go off this morning car would not start battery is only three months old?!? Any ideas!!!
Old 03-16-2015, 10:58 PM
cynicaldriver's Avatar
cynicaldriver
cynicaldriver is offline
Have someone you trust with electrical systems go through the wiring and check for breaks. This could be a simple matter of a bad grounding point, with an intermittent connection.
That turned out to be the problem on a vehicle I repaired back in November. The starter wasn't engaging all the time... Replaced it... New one had the same problem. So we dug deeper and found a nearly broken ground. It only had 3 or 4 copper strands hanging on to make the connection to the grounding point. This made the starter bog out because there was no place for the surge of electricity to bleed out. The same thing can happen to alternators.
Now, if the wires and connections are good, then you may have just gotten a bad alternator. Some of them can be rebuilt, so check into that. Rebuilding is often cheaper than replacing. Check to see if it is under warranty, as you may be able to get it replaced for free.
Keep in mind: alternators are more sensitive than most people think. If you have any kind of fluid leaks dumping onto the alternator (or spraying on them,) even in "minor" amounts, then it may cause the brushes to wear faster; or even cause the copper to corrode. Fix any leaks that may be contributing to unusual wear.
Ultimately, my money is on grounding issue.
Old 03-17-2015, 07:31 PM
scott91370's Avatar
scott91370
scott91370 is offline
I have had terrible luck with alternators. I replaced mine twice with non-Ford parts and they only lasted a week. Then my Ford ones have only lasted two years each.
Old 03-17-2015, 07:34 PM
senix's Avatar
senix
senix is online now
Received 1,414 Likes on 1,009 Posts
I would buy a new one, not a rebuilt.
Old 02-13-2016, 01:43 AM
pebblez75's Avatar
pebblez75
pebblez75 is offline
Question Flickering Battery and Oil Light
I have a 2001 Ford Escape 6 CYL XLT and my battery light flickers and sometimes my oil light flickers as well. Any ideas what this could be? My truck only has 89,000 miles.
Ismael Rivas
Modular V10 (6.8l)
01-03-2017 04:43 PM
Tidife
06-06-2014 08:53 AM
DavidHaile
06-21-2005 04:14 PM
carlo
Electrical Systems/Wiring
12-30-2003 01:20 PM
Brandon
08-04-1999 08:33 AM
Quick Reply: AlternaYor problems!!
