Rear end pinion help
Welcome to FTE:
Pinion adjustment would be something done when setting up the differential. If you tinkered with the differential and were just hoping to put it all back together the way it came apart, you are in for a sorry surprise.
If you axle is merely worn (or worn out) and clunks (or is on the verge of breaking) then you either run it or replace the ring and pinion, again with proper set up.
IMO setting up a rear axle is probably 8 on a scale of 10 for automotive type jobs. Find a shop that knows your vehicle to have it done, or if you must diy, be prepared to learn a new hobby as you may be doing it 2 or more times.
But see post 2 first.....
Tomahawk2506
08-23-2012 11:22 PM
Micginish
27
01-24-2006 01:40 PM
germanyvince
02-05-2005 08:02 PM
