Not charging
Welcome to FTE!
Here's a good link to get you started, with some troubleshooting. You will need a DVM or DMM (digital voltmeter or multimeter).
http://www.aa1car.com/library/charging_checks.htm
It's important to keep the battery on a charger overnight and/or top it off till things get sorted out. They will quickly lose capacity or even be ruined if chronically undercharged. And a defective battery presents a serious load to the charging system and can damage it.
Check for voltage on the green with red stripe on the alt with the key on it won't be 12 volts but should have a voltage value. Yellow with white stripe should have 12 volts all the time. With truck running check voltage at the big post on the alternator shoul be 14v + then check it at the battery should be 14v+ if the battery is down in the 12v range then you need to check the fusible links.
Does the engine run?
If so it would not be the ignition switch.
Iv replaced the cluster how would the cluster have to do with the changing system
The wire you said was dead with the key on that turns the alternator on passes through the cluster. If someone puts a 1994 or 1995 cluster in a 1992 or 1993 truck the alternator will not charge as the cluster plugs are wired different.
Did you not say above you did not change the cluster?
getrdone
11-06-2005 06:15 PM
