Need the Ranger experts advice... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-15-2015, 08:45 PM
Whitetail90 Whitetail90 is offline
Whitetail90 is starting off with a positive reputation.
I just bought a 87 ranger reg cab 5 speed, 4x4 with a bad 2.9 motor. I've heard the 2.9 was not the best engine and was worried about replacing it with another one. I seen where some guys have done a 4.0 swap but didn't know what all I would have to do? Different wiring harness and computer? Would my manual tranny hold up to the 4.0? Thanks for any advice
Old 03-15-2015, 09:06 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The 2.9 wasn't a very good motor both the 3.0 and 4.0 are much better, but to swap one of those you pretty much need a donor truck
Old 03-15-2015, 09:21 PM
I know the bell housing is the same so my manual tranny will work. I was just hoping someone would chime in who has swapped a 3.0 or a 4.0 in. I think I'll need the wiring harness of the donor truck and computer right?
Old 03-15-2015, 11:44 PM
Conanski's Avatar
Yes you will need the complete wiring harness and computer and you want to make sure you stay with an older OBD1 truck ('95 or older) or else you get into the much more complicated OBD2 system that needs the dash cluster and other parts. And just to be clear it's not likely any of the engine bay wiring in your '87 would be compatible with the wiring for a newer motor so you want all of it.
Old 03-16-2015, 11:41 AM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
FTE NorCal chapter LDR
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
There are articles on swapping a 4.0 into an older or different vehicle here:
Ford Ranger 4.0L Engine Swap FAQs
Jim
Old 03-16-2015, 10:26 PM
Thanks! Part of me wants to find another running 2.9 but the reliability of it scares me.....
Old 03-17-2015, 12:54 AM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to beholdtwigsV10 is a splendid one to behold
The 2.9 isn't necessarily the best engine ever built but not the worst either. I just swapped in a fresher 2.9 into my 89 Ranger that had 220,000 miles on the original motor myself. The PO definitely wasn't big on maintenance and I was impressed it actually ran that long.
If you were to go the new 2.9 route find a 89 or newer with the better heads and DON'T over heat it! And don't do extended oil changes!
Old 03-17-2015, 08:33 AM
That's what I'd rather do I think. If I got a newer 2.9 with the better heads, is everything the exact same when I go to hook everything up?
Old 03-17-2015, 08:53 AM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.heymrdj has a good reputation on FTE.
Just get a good remanned 2.9 and take care of the engine. The engine isn't really that bad, and you should never be overheating a motor anyways. If something starts going wrong, stop and turn it off!
Old 03-17-2015, 09:02 AM
Yeah I think that's the route I'd like to go. Do you know a good place to get a remanded 2.9?
Old 03-17-2015, 09:09 AM
heymrdj's Avatar
Quote:
Well Jasper used to carry them...but it doesn't seem like they do anymore. If there's any good builders around, I would consider having your current 2.9 block rebuilt. If not, I'd grab a junk yard 2.9 that's in good shape and take it to a good builder. Shouldn't be a ridiculous price. Polish ports, crank, new rod bearings, water pump, rings, gaskets.
Old 03-17-2015, 02:01 PM
I called my local salvage yard, they don't have any 2.9 motors. They do have several early 90's ford 4.0 motors with wiring harness and everything for $300. If I go that route, I'll have to Change out my dash as well right?
Old 03-17-2015, 04:43 PM
Nighteyez's Avatar
Not if it is a 91-94 engine. Only 95 and later.
Jim
Old 03-18-2015, 06:42 AM
Would my fm145 handle the 4.0 or would I need to upgrade to a M50d-R1 from a 4.0? I don't hot rod my vehicles, just want it to last
2.9l heads 1973dieselhighboy 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 10-04-2015 08:11 PM
trans question?? please help oldman56 Ranger & B-Series 2 07-04-2015 07:11 PM
2.9l transmission compatibles country_kyle01 Ranger & B-Series 3 04-18-2015 01:55 AM
4 Cylinder in Bronco II? jimg Engine Swaps 0 01-21-2006 06:22 PM
Best Exhaust for a 4.0L Ranger noremac19 Exhaust Systems 3 11-21-2002 04:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
