Random miss under load...
Old 03-15-2015, 09:41 AM
dlquinton's Avatar
dlquinton
dlquinton is offline
I have an '89 F150 4x4 with a 5.0. Lately it's developed a random miss when under load with a loss of power. It runs smoothly when cruising at highway speed, but when I reach a hill, or when I need to accelerate it starts to miss and looses power. It has less than 5,000 on a tune-up (cap, plugs, rotor and wires) and I checked the timing and it's still at 10 BTC. Yesterday, since I had a spare coil laying around, I switch that out too and there's no difference.
What would be the next most likely reason(s)?
Old 03-15-2015, 10:42 AM
bashby's Avatar
bashby
bashby is offline
What brand tune up parts did you use? I've seen a lot of plug wires fail in no time.
Old 03-15-2015, 11:39 AM
broncoderek's Avatar
broncoderek
broncoderek is offline
Vaccuum leak?
Old 03-15-2015, 03:17 PM
dlquinton's Avatar
dlquinton
I got decent quality from a local independent parts store, but I went ahead and followed your advice anyway. They are within spec according the information that I found on this thread...https://www.ford-trucks.com/forums/2...e-testing.html
Old 03-15-2015, 11:25 PM
dlquinton's Avatar
dlquinton
Since my last post, I've checked all of the vacuum lines, the fuel pressure, etc. without finding any problems. I finally decided to go back to the plug wires and take a closer look. Even though the ohms tested ok, I found where 7 and 8 were arcing near the dist. cap. I found a good diagram here ( 1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s pictures, videos, and sounds | SuperMotors.net ) along with a ton of other useful information about my truck and installed a new set of MSD's. The thing runs great now.
Thanks for the help, bashby!
Here's the diagram...
5Fingerride
05-31-2015 09:22 PM
danger-ranger93
06-02-2010 10:09 PM
Bayer-Z28
11-25-2009 10:21 PM
Wangert
11-21-2005 05:37 PM
lanero
04-14-2001 10:00 PM
Quick Reply: Random miss under load...
