Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
EFI on a budget for my 351m
Old 03-14-2015, 09:18 PM
akforceten's Avatar
akforceten akforceten is offline
akforceten is starting off with a positive reputation.
I have been doing a ton of research on this subject an I will be using the GM TBI set up .I have found wiring diagrams on what to use. I can source all the parts from the wrecking yard . The computer will need to be re flashed .I got my engine wiring harness from a 1990 suburban with a 350 v8 cause these harnesses are almost stand alone from the factory
"START HERE"--Fuel Injection FAQ--"START HERE" - Binder Planet Forums
This is where i found a lot of good info an the wiring diagrams
This build is going to take awhile as i'm doing everything my self like going though the wiring harness then making the TBI adapter. Okay here are some pics of what i got so far
Click the image to open in full size.
the last pic i have the harness weeded out of all unnecessary wires
__________________
Oregon Charter Member
1972 Ford f-350 4x4
1978 Ford Bronco
http://www.supermotors.net/registry/21939
Old 03-14-2015, 09:50 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
More power to ya. You're a brave soul in taking on a GM TBI. Subscribed.
A couple of magazine articles for others' background:
Carburetor to TBI Conversion - Hot Rod Magazine
A Homemade TBI Conversion for $904
Old 03-15-2015, 12:14 AM
Jdeshler's Avatar
Jdeshler Jdeshler is online now
Jdeshler has a good reputation on FTE.Jdeshler has a good reputation on FTE.Jdeshler has a good reputation on FTE.
Been debating this for years.. Subscribed..
__________________
~James lower Alabama
99 f350 4x4 7.3 dually..........71 Chevelle 454
66 f100 4x4 302....................64 C10 283
79 f250 supercab 351m.......78 f100 300
51 Chevy wrecker.................48 john Deere model b
Old 03-15-2015, 01:53 AM
EP145's Avatar
EP145 EP145 is offline
EP145 is starting off with a positive reputation.
Good luck, to bad it says GM but it should work well I'll be watching.
__________________
73 F100 2wd SB EFI 351w AOD
Old 03-15-2015, 09:52 AM
akforceten's Avatar
My plan is to use this on my 78 bronco an my FE 390. Once i got things down to the basics it seems to be rather simple to do this type of project .The computer tuning is the only thing i for see to take a few tries to get it perfect. For the bronco i will be using the stock duraspark distributor. on the FE i will be making a hybrid GM/dursspark distributor . The goals are for quick starting an some more MPG'S
__________________
1972 Ford f-350 4x4
1978 Ford Bronco
Old 03-15-2015, 02:11 PM
NMFirstF2504X4's Avatar
NMFirstF2504X4 NMFirstF2504X4 is offline
NMFirstF2504X4 is starting off with a positive reputation.
Interesting idea. Subscribed and looking forward to seeing your progress.
__________________
77.5 F250 4X4, 351M, 4-spd, 4" lift, 35" BFGs
Old 03-15-2015, 03:46 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Have you considered the TB Ford set up used in the early to mid 80'S ??
__________________
[/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
Old 03-15-2015, 04:15 PM
akforceten's Avatar
Yes I did an I found more support for the GM TBI plus at the wrecking yard i work at there is a ton of GM TBI stuff to pick from an zero ford TBI stuff . I already have gotten all the GM stufff Well back to sifting though wires
__________________
1972 Ford f-350 4x4
1978 Ford Bronco
Old 03-16-2015, 09:43 AM
akforceten's Avatar
Okay i got the first harness done today.I eliminated the EGR knock sensors an the ESC . These things will turned off when computer is reflashed. For timing control i'm using the ignition module out of the GM distributor along with the GM coil to. ok here some pics of the finished harness
soldering wires
I got it stand alone 2 grounds 1 batt 1 key on source. I will be using 2 relays on thw batt an key on wired
__________________
1972 Ford f-350 4x4
1978 Ford Bronco
Old 03-16-2015, 10:39 AM
ZarK-eh's Avatar
ZarK-eh ZarK-eh is offline
ZarK-eh is starting off with a positive reputation.
When I did my EFI, I used the power feeds to the Ignition Module. I cut the plug off the Ignition module then wired in some Diodes to power the Relay. The Ignition Module gets power at the start and run through this connector and the Diodes prevent power from backfeeding the other circuit. Worked a charm!
I suppose with a good sized Diode, you could power the EFI computer directly off these two wires kinda like how the Ignition Module does it.
Old 03-16-2015, 01:42 PM
TheMonson TheMonson is online now
TheMonson is starting off with a positive reputation.
the.monson
I do not possess the skills to pull this off (yet) but have wondered how hard it would be to adapt this system onto something (anything) else. Subscribed.
Old 03-16-2015, 01:53 PM
greentruck72's Avatar
greentruck72 greentruck72 is offline
greentruck72 is starting off with a positive reputation.
sounds cool, i have thought about going with a holley terminator, or the eldelbrock multiport, but i have little money to use on the truck so that will be a while, but very sweet idea.
Old 03-20-2015, 11:43 PM
54Hydro 54Hydro is offline
54Hydro is starting off with a positive reputation.
GM TBI will never be a high performance setup, so don't expect that. There is far more processing power in your cell phone than in that old brainbox. If someone were looking for a higher perfoming EFI the Holley Terminator, Edelbrock E-Street, MSD Atomic EFI, and F.A.S.T. EZ-EFI or EZ-EFI 2.0 would be a better setup. MSD and the F.A.S.T. 2.0 can also connect to the distributors made by those companies to control spark timing.
__________________
Oregon chapter member
ASE Master Technician
Old 03-21-2015, 10:19 AM
shaker666 shaker666 is offline
shaker666 is starting off with a positive reputation.
I used a junkyard Mustang 5.0 harness and computer, modified it for EDIS8 to get rid of the distributor, and used some adapter plates to mount a Lightning 351W lower intake to my 400. Runs like a champ and fully tuneable SEFI with the laptop.
Old 03-21-2015, 08:58 PM
akforceten's Avatar
High performance is not what i'm going for an all those aftermarket systems are way past any budget i could ever afford .I got the wiring harness laid out on the engine for a trail fit an to figure out whhere i need to fab up brackets for map senser an the ignition module .okay pic time
__________________
1972 Ford f-350 4x4
1978 Ford Bronco
Similar Threads
HID Projector Retrofit - HID's The RIGHT Way Evan_P 1987 - 1996 F150 & Larger F-Series Trucks 34 Today 04:50 PM
79 F-350 restoration ranger429 1973 - 1979 F-100 & Larger F-Series Trucks 212 11-10-2013 09:55 AM
Bronco gets a new floor pan. AbandonedBronco 1978 - 1996 Big Bronco 8 11-14-2011 08:49 AM
Truck Build 77 F150 Custom Lots of pics JFlom77 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-20-2010 04:14 PM
E4OD Transgo shift kit install hav24wheel 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2009 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
