EFI on a budget for my 351m
Nice job shaker666 ! Thank you Jdeshler . I'm confident i will pull this off but this is only one part of a bigger project ! I know i will get bugged when this works great lol. I know I will be bugged when this works great It is a 1978 ford bronco that i have started with a frame an a rust free tub .Here is the link to my build thread
https://www.ford-trucks.com/forums/9...o-take-it.html
This project has been on the back burner for awhile it is a very slow build due to the lack of $$$$$$$$$$$$$$$$$$$$$ and there is a couple of other projects that have priority right now. So enjoy reading the other thread an i will keep everyone updated . Right now total cost for this EFI swap is less than $100
Cool, I had a 64 F100 with a 400 in it with an RV cam and a Carter AFB in High School, man did I beat that engine up and it keep running the entire time.
#28
Okay its update time: I have been wondering how i was going to mount the coil and the ignition module. Then one day while i was working at the wrecking yard I saw a coil bracket out of a 97 suburban that had it's ignition module attached to the coil bracket well with a little modification i was able to mount it to the fire wall and fabbed up a piece of aluminum as a heat sink for the ignition module okay here are some pics
coil bracket mounted on firewall bracket
