F150 help
They're very close but the Ecoboost does have a little more power:
Eco: 365hp 420lb-ft torque
5.0: 360hp 380lb-ft torque
From personal experience, I have the 5.0 and I tow on a regular basis. I usually pull a 10,000lb-gvwr dump trailer with no problems. The heaviest I've hauled is a small SUV on a very large trailer. I've never had the engine struggle, the suspension is the weak link. In my opinion your not guna tell much of a difference when using the Eco or 5.0. Two of my good friends have the Eco and we can't tell the difference when towing. Hope this helps your decision, I don't think you can go wrong with either choice.
First of all, Welcome to FTE!
Both are great engines. Both will net you similar fuel economy numbers while empty. Remember that the ecoboost is a forced induction motor, so when you are in the boost, you will be using more fuel. The ecoboost torque comes in at a much lower RPM than the 5.0L, peak torque is available at 2500 RPM vs 4250 RPM. If you are used to a diesel, the torque output of the ecoboost may feel more similar to you. Depending on what you are towing, both motors will more than likely get the job done.
How much weight are you towing and how frequently? As mentioned above, the f150 is capable, but does have it's legal load/towing limitations.
The best suggestion anyone here can give you is to DRIVE them both and decide for yourself which feels right. Be sure to post up pics of whatever you decide (we like pics here) and good luck
EDIT: also, here is a graph with the torque output of the 4 available motors. This may help in your decision making process:
First of all, Welcome to FTE! Both are great engines. Both will net you similar fuel economy numbers while empty. Remember that the ecoboost is a forced induction motor, so when you are in the boost, you will be using more fuel. The ecoboost torque comes in at a much lower RPM than the 5.0L, peak torque is available at 2500 RPM vs 4250 RPM. If you are used to a diesel, the torque output of the ecoboost may feel more similar to you. Depending on what you are towing, both motors will more than likely get the job done. How much weight are you towing and how frequently? As mentioned above, the f150 is capable, but does have it's legal load/towing limitations. The best suggestion anyone here can give you is to DRIVE them both and decide for yourself which feels right. Be sure to post up pics of whatever you decide (we like pics here) and good luck EDIT: also, here is a graph with the torque output of the 4 available motors. This may help in your decision making process:
Something we failed to mention are the different gears. They can greatly affect how the truck pulls. 3.73's work for me...I don't know if I would go any higher such as the 3.55's. That's not a whole lot of input on my part but definitely something to think about.
With the 5.0 and 3.73 gears I've managed to average 23mpg on a 3hr trip to camp when I had stock suspension/tires. Very little 4 lane highway driving. I'm not sure the 3.55 gears would get any better gas mileage but you don't want those for towing heavy anyways.
mike b
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-30-2003 12:04 PM
