Up Pipe Options
Old 03-14-2015, 06:13 PM
pinbill's Avatar
pinbill
pinbill is offline
Up Pipe Options
Hello,
I am doing an e fuel upgrade. My babys butt manifold broke taking a bolt out of it. It seemed real loose after I removed the turbo. I am thinking I have a boost leak and it needed to be replaced or have new gaskets. I was only getting 10# of boost at WOT.
What should my boost numbers be like?
Where is the best place to get bellowed pipes?
Thanks,
Bil
Old 03-14-2015, 06:31 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I bought Irates Up-pipes
Old 03-14-2015, 07:18 PM
pinbill's Avatar
pinbill
pinbill is offline
Did the irate pipes come with a new manifold? In the picture it looks like it is welded to the pipes.
Old 03-15-2015, 07:13 AM
Diesel_Brad
Irates pipes are 1 piece
Old 03-15-2015, 11:28 AM
hijo202's Avatar
hijo202
hijo202 is offline
Those are nice. Hopefully I will grab a set later this year
Old 03-15-2015, 12:31 PM
Diesel_Brad
I recommend NOT using their hardware. Go to Ford and buy the OEM stuff, WAY better
Old 03-17-2015, 07:21 PM
pinbill's Avatar
pinbill
pinbill is offline
I bought the uptake pipes from Riff Raff. Hopefully they are nice.
Speaking of bolts, I need new fasteners for my y pipe, turbo collector, or babys butt manifold. I tried to get them from the ford dealer but didn't want to trust the parts guy. I pulled off two studs, two nuts, and two bolts. Does anyone know the parts numbers for these?
Thanks,
Bill
Old 03-17-2015, 08:24 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Old 03-17-2015, 09:14 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Boom... OEM Baby.
Up-pipe Reinstall Hardware Kit 94-03 - Riffraff Diesel Performance
Old 03-17-2015, 09:35 PM
pinbill's Avatar
pinbill
pinbill is offline
I am looking for the bolts, studs, and nuts that connect the turbo to the y manifold, not the up pipe bolts. I called and asked Riff Raff about them the other day. They said the studs were so expensive they don't sell them anymore.
Old 03-18-2015, 11:33 AM
Diesel_Brad
Just reuse your old ones. They don't go bad
Old 03-18-2015, 08:01 PM
pinbill's Avatar
pinbill
pinbill is offline
I couldn't get the one stud off the old manifold.
Old 03-18-2015, 08:24 PM
Diesel_Brad
Did you use heat?
Old 03-18-2015, 09:00 PM
pinbill's Avatar
pinbill
pinbill is offline
I soaked them for a few days in PB then heated them. The nuts aren't in the best shape after me wrenching on them.
Old 03-18-2015, 09:01 PM
pinbill's Avatar
pinbill
pinbill is offline
I went to the dealer today. The parts guy said they were $28 a bolt. Then he said "those diesel parts are expensive." I have the parts numbers and I will get some of the internet.
Quick Reply: Up Pipe Options
