Help Pls - 2nd Battery or Larger Alt needed ?
Added 6 PIAA 520s on front and 2 KC's flood on the back of my SURCO Safari rack.
Im a novice at this, but wondering if I will need to add second bat or larger alt.
03 Eddie B 6.8/V10 4x4.
Also have 1200 amps running six 5x7 Access Focal speakers, pioneer 4000NEX and 12"sub. Lights will not be on for any serious length of time 10-15mins at a time.
thoughts appreciated
JP
JP
on
Turn radio up and all lights on while the truck is running. If you notice a drop in power, I would say you need a larger amp. If you are going to be running all these a lot when the truck is off, I would say throw another battery in there so you will be able to start it back up.
Disclaimer*** This advice is based only off of my personal experience with vehicle electronics and I do not claim to be any type of expert in the matter.
If looking to add a second battery check out the E350 frame mounted tray's.
How solid is yout charging system currently?
This is where I would start first. Also what alternator and battery do you have? My time truck has the 850 Motorcraft and the tow package alternator which produces a higher amperage. If looking to add a second battery check out the E350 frame mounted tray's. How solid is yout charging system currently?
I have that same alt u have and i run c&d 140ah batterys 3 total and its pretty good. Stays in high 12s when playing fult tilt which is pretty dam good. They have duel alt brackets for ours that are pretty cheap. Think they used them for ambulances for duel alts. And if u did that and got another alt like u have that would be the cheapest and also have 400+ amp. And ya the Diesel trucks have a second battery in the engine bay which v10 guys can do too
Engine bay is cramped on v10s. Emissions equipment takes up all available space on both sides. you can fit dual optimas or a dual smaller batteries where the stock battery goes if you turn them sideways. Im not a fan of optimas in any way, so this limits options. It would be nice to toss another odyssey where the powerstroke's second battery lives. Not a fan of the frame rail mounts due to exposure to elements and damage offroad.
If removed, the power steering reservoir needs to be moved forward an inch or two, which is not that hard of a task. You can get a generic plastic battery tray and trim it to fit. There might be a need to move a couple of other things a little but nothing major.
The canister could potentially be relocated but it is large. I will not comment on the legal aspects of the removal of emissions equipment but if you do remove the canister, fuel vapors from the tank vent out of the hose that attaches to it. If you plug the hose, the tank can become pressurized if you use a non-vented gas cap. If you don't plug the hose, you will get fuel vapors out of it, venting the the engine bay, which can be a bad situation.
The old Optimas were great. It seems quality went downhill after they were bought out. I had one for about 10 years that I just moved around from car to car. It finally died after being fully discharged too many times and I bought another. The new one died within a year. Gave up on them at that point after reading some reports.
Vapor canister for emissions. If removed, the power steering reservoir needs to be moved forward an inch or two, which is not that hard of a task. You can get a generic plastic battery tray and trim it to fit. There might be a need to move a couple of other things a little but nothing major. The canister could potentially be relocated but it is large. I will not comment on the legal aspects of the removal of emissions equipment but if you do remove the canister, fuel vapors from the tank vent out of the hose that attaches to it. If you plug the hose, the tank can become pressurized if you use a non-vented gas cap. If you don't plug the hose, you will get fuel vapors out of it, venting the the engine bay, which can be a bad situation. The old Optimas were great. It seems quality went downhill after they were bought out. I had one for about 10 years that I just moved around from car to car. It finally died after being fully discharged too many times and I bought another. The new one died within a year. Gave up on them at that point after reading some reports.
This post motivated me to go finish up my dual battery setup. I still need to go get a battery hold-down and run wiring, but this is what it might look like if someone decided to remove or relocate the vapor canister and relocate the power steering reservoir to fit a second group 65 battery.
