1990 F150 shutter/bump Possibly transmission?
Needing a little help, Im no expert on working on vehicles but I have the know how but not the experience. Transsmission is a 3 speed with overdrive 5.0 302 V8. For the past two or so weeks my truck has been running really weak, engine is running fine and fluids are great but when ever i accelerate it feels as if its weak. And when i get to higher speeds around 45 or 50 there seems to be a bumping feeling, almost like hitting somthing in the road. its not very violent but its very noticable. Sometimes it wont do it the whole time i drive the truck but other times it will do it often. Seems to shake the truck and i have been told that you can tell the truck shutters when you are behind me. No strange noises or high revs from the engine and the U joints are fine and the drive shafts arnt loose. And the last time i checked (bout 4 months ago) there was a good amount of dope in the rear axle chunk. Happens alot when the truck is in overdrive and I start up a incline, doesnt want to shift out of overdrive as fast as i would expect.
3 speed + overdrive makes it a 4-speed automatic transmission. There were two available in this vintage truck. The mechanical/hydraulic AOD and the electronic controlled E4OD. The troubleshooting path is completely different between the two.
Check the B-pillar (door jamb) stick on the driver side. Look for the Transmission Code.
Trans Code T is the AOD. Trans Code E is an E4OD. More than likely you have an AOD, but we all need to know for sure.
I havent had anysurging or suddenly have it cut off but i have noticed when starting to accelerate the truck almost shuts off completely
daltonjamesadams
02-27-2018 03:51 AM
wickedklown83
03-09-2010 12:01 PM
wozxxx86
10-20-2006 10:28 PM
