First 2017 Super duty pic?
#91
Does it matter? You will find out in a couple of weeks. However snarky you may suggest it, the grille under the camo looks exactly like the one in the prototype, and the lines of the truck are accurate.
So, I'll stick with the picture as a base of what it's going to resemble.
Doesn't really matter what it looks like to me. It may matter to some I guess. IMO, It's a Ford and it'll be sharp. I'll be buying one of the first F-350 CCLWB PSD to roll off the line.
For the rest of us who care about styling, let's hope Ford gets this right and it looks better than the spy picture suggests.
#92
What a nice thing to say about the new Ford truck..
BTW, I don't camp out, I just order it and write the man a check when it comes in.
So, my opinion is the only one that matters, and I'm sure the compliments will come the second I, or another 17' buyer posts a picture.
I'm picking up a new GMC 2500HD All Terrain Sonoma Red with black/red leather as a winter beater plow truck this weekend.
I suppose that looks like a porcelain toilet to you also, and maybe it does to some I guess, but it will make a fine work truck for me.
Funny, another member called me a brand loyalist.
The ironic thing is the name of this site, and he's a member just like you..
Trucks aren't the be all, end all for me. It's more about current style, latest technology, warranty, and a section 179.
Nothing would be more depressing than owing a brand new truck that looks the same as my first SD that I bought almost 19 years ago. That would truly suck to me.
So if it's a porcelain toilet with a diesel flusher, I'll be thrilled to death.
#93
Actually, aside from the square wheel arches, I kind of like the look of the current GM HD trucks. If you have the money to buy a brand new truck to use as a "winter beater," than I think that's great.
My point was that I'd like to buy one of these new trucks, but only if I think it's styled well.
#94
I have to spread it around town when I buy vehicles because most of the dealers are my customers. They all know what truck I use to plow, and what truck gets the custom accessories and wheels, along with a storage spot for the winter.
#95
#96
The thing is that, historically, what has always distinguished the Super Duties from the F150 is a taller, more pronounced grill. That's been essentially the visual 'key' for the Super Duties from the start, and has only gotten more prominent with each series. So it just doesn't make sense that Ford would do exactly the opposite this time around, and give the truck a wider, flatter grill like the one in the pic.
If I were to make a stab as to the new design, I'd say they'll probably look a lot like the new F-150, but more angular and with a slightly more vertical grill that protrudes a bit more. In fact, I'd probably say that if they toned down the Atlas a bit for the production F-150, they probably do the opposite for the SD and do a slightly beefier version. It just makes sense.
But who knows - I've been wrong once before. I suppose since they did a pronounced grill for the F-150, maybe someone in the design department said they needed to do a flat one on the SD to make it different.
But to me, what's in the pic is what you'd get if you took a 1980 F-250 and told the designer to bring it up to date. I suppose too if someone said 'make a cross between an f-150 and the Super Chief concept', you might also get something like this.
For the record, my favorite SD was the second generation - clean lines, tidy, businesslike. The current SD looks to me like it's wearing a chrome clown nose.
#97
#98
Im fortunate enough to be able to have two trucks. I buy two different brands so I have something different to drive.
I use the GM for winter plowing and for my business. It's also a double cab since I can't fit a crew cab with a plow in my garage at home. That takes Ram out of the running, and I hate, HATE the Ford Super Cab back seating area. Very uncomfortable if you have to carry someone in a pinch. I like the safety of the GM B pillar in the double cab over the non B Pillar of the Ford.
The Ford is my non work crew cab, and my daily driver until the snow flies.
#99
I think the custom likes this total differentiation - different cab, different bed, different nose, etc. Moving the SD in line with the way GM and RAM style their HD trucks may be cheaper, but not in the long run if customers are lost.
#101
If that is actually it, I like it. Definitely a better angle than that spy picture. After looking at that, the spy picture definitely hides a lot of the body lines and details. I never noticed it before but there is definitely the super duty letters stamped into the hood. The crappy picture along with the silver color really hid a lot in that picture.
#102
#103
If you compare the earlier pic, they look almost exactly the same. It's just a different view, which makes the front look 100% better than the original pic. The original pic had Super Duty stamped on the hood and so does this pic.
I think most of the body will be very close to a F150 with an modified front end to make them slightly different.
Just my opinion.....
#104
