Wiring humdinger for the brave - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-11-2015, 06:36 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
One thing I have noticed with my truck is everytime I pull a trailer with electric brakes the trailer brakes come on while backing up. What I didn't realize was that everyone o put the truck into reverse the brake lights come on as well. I knew there was a problem but just figured it was in the 7 prong connector. I figured I would tackle that today. I opened up the connector and huh. Looks pretty good inside. Plus it isn't wired to have backup lights into the plug. That wire ends by the fuel tank. So I start to unravel the electrical tape and come to a bundle of twisted together and taped up wires. I shuffle them around and alas the brake lights are off. I went under the truck to find my problem only to find that the wire going to the passenger side brake light was now disconnected. Hook it back up ant the brake lights go back on. Disconnect it and they go out again. Ok the problem must be in there right? Now here's where it gets interesting. If I remove the trailer backup light relay my truck lights work properly. Plug it back in and the brake lights are back on. Another thing I noticed. When hooked up to the trailer to stop the trailer brakes work flawlessly. But I according to my multimeter there is a constant supply of 12 volts to the trailer brake pin on the truck, whether it's in reverse or not. Anybody have any ideas ?
Old 03-11-2015, 10:08 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Interesting situation you have. IIRR the trucks that came with the trailer tow package, had 2 plugs that ran to the back of the truck. One had 3 wires, 2 for the turn signal, and the other was for the marker lights. The other had 2 wires, 1 was hot all the time with the key in the run position, which was for the trailer battery charge, and the other wire was for the trailer back up lights. I don't recall the wire colors though. It sounds like the constant 12 volts you have going to the brake pin is the battery charge wire, but if that was the case, the trailer brakes would be on all the time. Not much help, but here is a bump to the top.
Old 03-11-2015, 11:45 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
My brain is fried..sorry bub.I'll look tomorrow...
Old 03-12-2015, 12:12 AM
Yup. It's strange. And like I said if I remove the trailer backup lift relay or disconnect the passenger side brake light at the junction the brake lights go out. The brake controller seems to sense of the trailer is hooked up and I wonder if that's why it has voltage at the plug. Just a thought. I'm gonna think about it a bit. Then I may bring it to a friend. He's pretty good with electrical gremlins and I have faith in him.
Old 03-12-2015, 10:00 AM
Hussler's Avatar
Hussler Hussler is offline
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Factory wiring colors for 7 pin trailer connector ...
Yellow - Left turn lamp
Dark Green - Right turn lamp
Black/Lt Green - Backup Lamps
Orange - Battery charger
Brown/White - Marker lamps
Dark Green - Electric Brakes
White - Trailer Ground
Notice there are two Dark Green wires.
Old 03-12-2015, 11:04 AM
Interesting. That seems to make sense on where all my troubles could be. I bet if I find the trailer backup wire it will have power when I press the brakes. Thanks. That seems to make a lot of sense.
15' brake controller question levi'sford 6.7L Power Stroke Diesel 20 04-14-2016 04:00 PM
Passenger tail light(brake and turn signal) DrewG88 Electrical Systems/Wiring 9 04-08-2016 01:05 PM
Have a really tough one for you guys. Wiring Issue Ryan Silverthorn Electrical Systems/Wiring 1 10-04-2015 09:03 PM
Trailer connector-no brakes or turn signals RUSTANG67 2009 - 2014 F150 4 07-18-2015 08:25 PM
trailer brakes not working - need help Baicolt 1999 to 2016 Super Duty 2 04-22-2015 05:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
