Tire Suggestions PLEASE !!!
So ive been planning on getting super swamper boggers for my truck, but my buddy says theyll only last a summer but i have a hard time believing that. My trucks a daily driver, farm truck, and a mud truck. I hear the boggers get around 20K road miles before theyre junk ... I was wondering if a different kind of super swamper TSL tire would be better for a daily driver truck ... The boggers have the deepest tread so id figure they would last the longest... Any suggestions on tires and even tips to get more miles out of the tires would be greatly appreciated ... THANKS
Boggers are awesome, but maybe not for a DD. My friend had 38x12.5's on a Scrambler and it vibrated like crazy, an the howl? We lived about two miles from each other and at night, I could hear him until he got to his driveway!
OTOH, I had Radial TSL and LTB's. Both great tires and in never complained about longetivty.
Probably the same compound, I'd like to see what the contact area is like between the two.
I'd like to think the Boggers have more contact area so using my "logic", they'd last longer.
My LTB's were on an XJ with a spooled rear and still, I wouldn't complain about wear. I wish I could tell you how long they lasted.
My Radial TSL's were on a Samurai and then on a K5 and I sold them with lots of life left.
I had a set of TSL SX's (35"x15.5") that had about 25,000 miles on them before they were junk. Be warned that you may need to upgrade the speakers in your truck to cover the howling of any of those tires.
Currently, I recommend the Cooper Discoverer STT's for a streetable offroad tire.
My trucks lifted 6" and a 3" body lift on the way so I want to get 38" or bigger tires ... The boggers that i planned on ordering are 38.5x15x16.5 .... Id love to get normal offroad tires becuase of how much cheaper they are, but they dont come in big enough sizes, unless someone knows of any that do ? ... My logic is the same as broncoderek seeing that the boggers are very flat treaded theys make more contact with the road making an even, slow, tread wear, same as any bias tire for the most part ... Radials they say are better for roads but they are arched badly making the center wear out alot faster ... I love all the suggestions and help KEEP EM COMING !
I believe, with PROPER inflation (12 psi for my Samurai, 30+ psi for the same tire on my K5 Blazer) the contact patch is mostly square.
I know the tire will look high in the middle everywhere there's no ground contact but like I said, accounting for the load rating of the tire and the weight of the vehicle, contact patch should be flat and wear properly.
I just think by looking at tread patterns, the Bogger may have more rubber on the road at any given time than the TSL would.
That said, bias ply tires do have tougher sidewalls, so they stand up better to off-road abuse, especially at low inflation pressures. So if a lot of rock crawling is in the cards then it's possible that bias ply tires might last longer. But it won't be because of tread life.
If the truck is a pure mud machine, Boggers are unmatched except by tractor tires. If it is a multi-use truck that sees mud, dirt, rocks and trails, a regular TSL, SSR, TSLR, IROK, will perform better. Especially if any side hills are in the mix. Boggers are notorious for not having great side traction.
If you want them for looks and bragging rights, I get it.
