Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
SPONSORED BY:
Click HereAdvertisement
truck ran vantastic now barely runs at all
Old 03-10-2015, 09:43 PM
kramerpage's Avatar
kramerpage kramerpage is offline
kramerpage is starting off with a positive reputation.
Well you may remember my 2004 fx4 repair last month that I posted on this site.
I helped a friend out replacing plugs and boots, cleaning TB, new front brakes everything and several front end components. When I was done that truck ran bad ***. I just got a call tonight that the truck barely runs. So I headed over to look at it in the pouring rain thinking a vacuum line was off. No such luck. I could not find anything apparent during my inspection.
Here is whats going on
Check engine light on
ABS light on
brake pedal feels like manual brakes meaning you have to stand on them to get her to stop
VERY rough idle and stalls when coming to a stop.
Smooths out at 3000 RPM
Here is the original post of repairs last month. GeeeeWhiz
http://www.ford-trucks.com/forums/13...r-my-head.html
Now I did what I could do with a flashlight and raincoat...LOL
I told her not to drive it for now and I would come back during the day with tools.
Any ideas where to start? I know I know....What kinda question is that?
It seems like a vacuum leak but I have done no diagnostic work other than an under the hood visual inspection.
My big fear is that now I am married to this truck...I just wanted to help her out LOL
Old 03-11-2015, 07:42 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Big vacuum leak.
__________________
Speed is a question of money. How fast "CAN" you go?
Old 03-11-2015, 08:20 AM
bbender85's Avatar
bbender85 bbender85 is offline
bbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud of
brandon.c.bender bbender785
Quote:
Originally Posted by critterf1 View Post
Big vacuum leak.
sure sounds like it. what did you check last night on the system? just visual inspection?
__________________
Brandon
'04 F350 CCLB 6.0L, 4" turbo back, EGR delete, Atlas 40 FICM, blue spring, SGII, 2.8" minipack,
285's on 16x10's, DVD/audio goodies SOLD
'07 F150 Supercrew Lariat 6.5' box, 5.4l, 3.73 LS, 2" AS now in it's place.. pic to come.
Old 03-11-2015, 10:15 AM
kramerpage's Avatar
With the pouring rain I only did a visual to make sure no vacuum lines came off from my previous work. I plan on starting out with reading the code stored in the pcm and remove and inspect vacuum line from break booster. I would think it would be something simplistic but Im no mechanic so I will muddle my way thru it. The day before it ran great. No abs light and no check engine light and no rough idle. BIG vacuum leak is right guys LOL Maybe the booster diaphragm? I will update this thread to completion as I always do....
Old 03-11-2015, 02:43 PM
05_AlexF150's Avatar
05_AlexF150 05_AlexF150 is offline
05_AlexF150 is starting off with a positive reputation.
Here's my wild and crazy guess. Her FDM finally died from all the water. Check that out as soon as you have a chance.
Old 03-11-2015, 04:01 PM
kramerpage's Avatar
Quote:
Well I'm guessing that's front wheel drive module? We have had crazy amounts of water w rain and melting snow and iced up storm sewers. I will google it. Interesting. Thanks so much guy.
Old 03-11-2015, 04:15 PM
kramerpage's Avatar
Lol ok I said I'm not a mechanic. Fuel delivery module located on the drivers side rear axle. Nice. Can I go with a Dorman replacement or should I go w oem if this is found to be bad?
Old 03-11-2015, 04:33 PM
canstacker canstacker is offline
canstacker is starting off with a positive reputation.
The Dorman has the stand offs(to prevent corrosion) and should be fine. Rain may be the big clue here. Check for a third brake light leak, water can make it into the electrical connections and cause problems. Check ground straps and battery. That's all I got. Hope its something easy.
Old 03-11-2015, 06:54 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is starting off with a positive reputation.
Maybe the fuel but almost certainly a vacuum leak - maybe a hard old brake booster vacuum line broke.
__________________
2007 F-150 V6 5-Speed Manual
Old 03-11-2015, 08:13 PM
Quote:
I'm not a mechanic but a tinker is for sure.
someone said the Dorman brand is fine, I like the idea it has its own standoffs and that is good.
Good luck and my fingers are crossed for you.
Old 03-11-2015, 10:00 PM
1saxman's Avatar
We usually call it the Fuel Pump Driver Module but you are not having the symptoms for it. It causes failure to start and can be intermittent. Once the engine starts everything is normal until it dies. However, if the aluminum base is heavily corroded, you may as well replace it.
__________________
Old 03-12-2015, 08:11 AM
jr105 jr105 is offline
jr105 is starting off with a positive reputation.
I agree with 1saxman. Your symptoms are classic vacuum leak, not FPDM.
__________________
04 F150 STX
98 Corvette
Old 03-12-2015, 08:45 AM
kramerpage's Avatar
Quote:
Well they are out of town so the truck is locked up. Guess Im on hold till I can get a look at her Saturday. I will update then. Ive never been someones personal mechanic...LOL
Old 03-12-2015, 03:33 PM
kramerpage's Avatar
Codes are po171 and po 174. The vac line going to the break booster has no vacuum. It turns to metal and goes behind the engine. Anyone know where it goes?
Old 03-12-2015, 07:40 PM
kramerpage's Avatar
Well I suspect the brake booster line has come off the intake port nipple. I sprayed carb cleaner back there and the motor raced. I read you have to lower engine or raise cab. Lol are they kidding. I could not see it from below or above. Here I thought it was downhill from here after the spark plug feasco. Any tips or tricks for this repair guys? Thanks
Similar Threads
My 55 F100 oldwi 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 12-10-2013 12:53 PM
Hot rims benbuilder Brakes, Steering, Suspension, Tires, & Wheels 1 07-24-2013 12:00 PM
99 f150 4x4 Lariat-Both front brakes dragging? HELP fixitman1 1997 - 2003 F150 9 02-11-2013 08:36 PM
RestoMod DailyRod build thread! nothercrash 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-21-2010 06:52 PM
My New Truck... ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 64 12-13-2007 01:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
