Wheel cylinder upgrade for '67 Highboy?
Can I bump up the wheel cylinder size from 1 1/16" to 1 1/8" on the fronts without any issues? Will the stock master cylinder handle the xtra volume with the brakes properly adjusted? I can not find the correct front wheel cylinders for my 1967 Highboy. The NAPA cylinders come with a banjo type fitting instead of the inverted flare of current brake lines.
How about a rebuild kit for what you have? Hone, clean, replace rubber.
Also, be advised that going to a larger wheel cylinder will change the braking characteristics. In fact, your front cylinders will attack about 12% harder.
Yours are 1 1/16 for a reason. And yes, you just put more fluid in the m/c reservoir with larger wheel cylinders.
Well, O'Rielly was a strike-out.
The "correct" front cylinders came in and had the same DIN/bubble flare as the NAPA parts. I need the SAE double flare seat. The odd part is that the threads are 3/8-24. Are the brass inserts available (that seem to be the missing ingredient) to make these parts useable for a double flare?
alchemist1
09-30-2012 09:59 PM
transam525
06-11-2011 12:21 AM
kd123
01-06-2006 05:48 PM
