Why is my Serpentine Belt Out of Production?
My old tensioner is identical to the one in Post #15, and my routing sticker is identical to the WHITE one (havent looked to see if a black one is buried under it).
I think I'll get another 1237 while I can . I'm thinking that while a 1227 might fit with my new tensioner, it may be a bit tight. Perhaps if I had smaller idler pulleys...
What am I missing about why angle grinders are in those pics? ;-)
I can't tell by looking at that pic if that is a true motorcraft BT50 or a parts store equivalent.
My recent experience is that the parts store equivalent of the BT50 has both pulleys as part of the single bolt on assembly, but that only the ribbed pulley pivots, the smooth is fixed. This style does not give enough pivoting movement to fit a 122" belt.
When I replaced that with a real motor craft BT50, the style that both pulleys pivot together, there was enough movement to fit the 122" belt. It was at the tightest of the three tension marks, but it fit nicely.
Resendiz
10-10-2016 03:41 PM
Spktyr
23
06-17-2012 01:47 PM
Dstosh
12-04-2007 08:52 PM
