aluminum water pump???
Old 03-10-2015, 02:14 PM
greentruck72's Avatar
greentruck72
greentruck72 is offline
does any one make a aluminum water pump for a 390? i have looked but haven't found a much on the subject and do they make a chrome timing cover for a 390 as well
Old 03-10-2015, 04:26 PM
69cj's Avatar
69cj
69cj is offline
Have you tried Summit?
Old 03-10-2015, 10:42 PM
Osiyo59's Avatar
Osiyo59
Osiyo59 is offline
The timing cover is aluminum and I don't believe anyone is reproducing it. Edelbrock makes an aluminum water pump for the FE engines. Just picked one up for my 428.
Old 03-11-2015, 10:39 AM
abyars111's Avatar
abyars111
abyars111 is offline
I have a Edelbrock aluminum water pump. I like it. My alternator, p.s. pump & a/c brackets fit it well. You have to be careful, some of the China cast pumps don't fit accessory brackets well.
Old 03-12-2015, 08:15 AM
greentruck72
was the eldelbrock a direct replacement(meaning every thing fit)?
Old 03-12-2015, 08:26 AM
abyars111's Avatar
abyars111
Yes, direct replacement. Everything fit perfectly.
Old 03-12-2015, 08:28 AM
greentruck72
where did you order yours from?
Old 03-12-2015, 08:32 AM
abyars111's Avatar
abyars111
At the time I found the best price at Jegs. I bought it back in the summer last year. Just shop around online.
Old 03-12-2015, 08:39 AM
greentruck72
yeah will do thanks for the info, quick question are you running headers if so could you recommend which ones would be good to get
Old 03-12-2015, 09:12 AM
abyars111's Avatar
abyars111
I'm running Stan's Tri-y headers. I like them they fit well and are well made. I did have to clearance the frame slightly on the passenger side. My other choice would be Sanderson Headers. These are both shorter in design and do well on a truck. HiHoSilver has a great right up on installing his Sandersons in the 1967-1972 forum. You can run a stock starter with either of those two sets of headers. These are not the cheapest choice but I feel they are well made.
Old 03-12-2015, 10:42 PM
rockittsled's Avatar
rockittsled
rockittsled is offline
.... do they make a chrome timing cover for a 390 as well
No, not chrome, but it is being repo'd and upgraded as well
FE Timing Covers
FE Timing Cover
Shelby Aluminum Timing Cover | Call Us @ 707-836-1534 | Carroll Shelby Engine Company
fastphil
15
03-30-2018 01:09 PM
thunderbolt61
09-28-2014 03:53 PM
77short4x4
05-27-2013 03:46 PM
bnmc98
03-20-2010 09:23 AM
Ford_Six
04-25-2005 09:26 AM
Quick Reply: aluminum water pump???
