Bad vibration from front end
Hi I have a 1999 f250 4x4 superduty that I got a few months ago and I have a bad vibration coming from somewhere in my front end. I can get it to stop if I swich it to 4wd. I have tried replacing the hub assemblies but it still does it. I was wondering if anybody has had anything like this happen to there truck
Hub assembly needle bearings that ride on the axle shaft when you put it it 4x4 the axle shaft spins also so the noise stops
Listen for a sound that sounds like birds chirping or a clicking sound.
Drive you truck at low speed listen do it in/out of 4wd. My exp is the vibration comes after the birds chirp, shortly after that your u joint goes to u joint heaven...
haha we had a 98 f250 light duty that ford morphed together from multiple years and 2wd - 4x4 parts.
When you'd hit a bump, the entire truck would shake and chatter like you had 2 flat tires up front.
We rebuild the front end and it still did it. Pitman arm turned out to be the cause of it.
Note the bright area on the cap. This is the cap rotating in the trunnion. Failure is just a few miles away. You will often hear a chirping or ticking sound from the dry bearings, which are the cause of the cap rotating.
If you have a zerk fitting in your replacement u joint here is a tip that will add life and miles to the u joint.
Grease them BEFORE you install. Grease and exercise the joint, repeat untill you get visible grease past the seals.
What I often do is remove the caps and grease the joint insuring I have a good amount of grease out of each axle. U Joints are notorious for getting air locks and typically when we grease them at the first sign of grease we stop. If you will take off the caps and fill the grease tunnels, the replace the caps by pushing and turning as you put them on. Exercise the u joint by rotating the caps while adding grease, the allows the air to escape.
battmanf16
1997-2006 Expedition & Navigator
22
03-11-2020 11:36 PM
