1990 5.0 sporadic rough idle - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Log In
Old 03-09-2015, 06:38 PM
DattMavis's Avatar
DattMavis DattMavis is offline
DattMavis is starting off with a positive reputation.
DattMavis420
My 1990 F-150 5.0 EFI has been having rough idle problems for a while now. I thought I had it fixed recently, but its come back again. Sometimes when I crank it after its already warmed up, the RPMs will bounce between 600-900. (it also takes 4-5 seconds to crank sometimes, while others it starts right up, though I'm not sure if thats related). Then sometimes when I'm I'm driving around and come to a stop, it will do the same sort of thing, maybe 500-1100 RPM at most though. It will almost choke down, then surge back up and try and jerk forward. If I let it roll forward a few feet, of just sit there for about 10 seconds or so, it usually stops. If it hasn't stopped by the time i get moving again, it might hesitate a little, but if i give it some gas it goes and runs fine. There doesn't seem to be any particular situation that causes it to start doing this, and i'm at a loss. Any ideas?
Also, heres a list of things I've already repaired, and one of known existing problems, if that helps narrow it down.
Repairs made:
Idle Air Bypass valve
New plugs, wires, cap, rotor
New belt
New alternator
Replaced all vacuum lines (routed correctly, double checked)
New PCV valve
New intake and valve cover gaskets
New starter relay
Cleaned throttle body
Oil changed >1k Miles ago
Ran injector cleaner a few months ago and a seafoam on the last tank, but neither has made a lasting difference
Known issues:
Water pump, very small leak @ gasket but i'm about to replace the whole thing
large hole rusted through muffler, also about to replace
Rear main seal leak, very small, but i doubt its related (not looking forward to replacing it either)
Any ideas or suggestions are greatly appreciated, thanks!
Old 03-09-2015, 06:43 PM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
codes? + 4 letters.
__________________
'89 F2 4x4, HPKP D60, ZF5, Fixed output 1356, 351: ported/milled gt40P's, 10.5:1, 35-255-5, .060 bore, long tubes, etc.
-'02 dodge 2500 6 spd cummins, 300k miles: 545/1240 rwhp/tq-DD/tow rig
-'00 SS camaro 6 spd, NA & stock cube: 440/425 rwhp/tq-for rippin
-'84 FJ60 LC - 4bt/nv5600; 320/750 whp/tq
-'00 7.3 e350 chateau; 4x4 zf6
Old 03-09-2015, 06:57 PM
DattMavis's Avatar
DattMavis420
Quote:
Originally Posted by '89F2urd View Post
codes? + 4 letters.
I'll have to borrow a reader tomorrow and check. Do you know where the OBD port is? I haven't seen it while I've been under the dash lately, but I haven't been looking for it specifically. The check engine light hasn't come on, but i don't know if it has one even. Wouldn't surprise me if the bulb was out if it does.
Old 03-26-2015, 06:12 PM
DattMavis's Avatar
DattMavis420
Pulled my codes today
KOEO (key off engine off):
22: Manifold Absolute Pressure (MAP) sensor out of Self-Test range
It was warmed up, i got the same result both times i tested, but not when I did the KOER
KOER (Key off engine running):
25: Knock not sensed during Dynamic Response Test (operator error)
I thought I did it right, hit the throttle after the single flash that came after engine ID. Not itching to do it again, that truck hardly ever sees 3k RPM and it blew out a cloud of smoke when I did it.
41: HEGO sensor circuit indicates system lean
Any ideas on where to start on this? Could any of these be causing the running problem i've mentioned?
__________________
Work Truck: 1990 F-150 XLT Lariat- 5.0 EFI- AOD Trans- 3.55 Ford Rear-end
Project: 1970 F-100 Ranger- 302 Windsor- 3-Speed Manual
Fix your quiet warning chime My 1990 F150 Resto/Mod Log
Old 03-26-2015, 06:40 PM
'89F2urd's Avatar
Map sensor. Run tests via a manual or google search. Or swap out a jy map and see if symptoms change
__________________
Old 03-26-2015, 07:32 PM
DattMavis's Avatar
DattMavis420
Ok i will test it tomorrow when i've got some light to work with.
__________________
Old 03-27-2015, 07:28 PM
DattMavis's Avatar
DattMavis420
Got a loaner vacuum pump and tested MAP sensor using these instructions: Part 2 -Manifold Absolute Pressure MAP Sensor Test (Ford 4.9L, 5.0L, 5.8L)
Hz was a little higher than listed at 0 Bar (160-165Hz) but decreased smoothly towards -2.0 Bar and was right at 101Hz. Tested multiple times, and the guide said HZ readings could vary slightly between vehicles.
Also tried tapping it with some pliers while I took the reading, stayed stable.
Also tried wiggling the connector, also stayed stable.
Then I connected the hose to the MAP and removed the other end from the intake. Applied vacuum and it held it, so the hose is fine.
Don't know what to do next, I guess i'm going to clear codes, drive normally, and see if it happens again,
Side note: ever since I did the KOER test (which miraculously revived my CEL) it's been running pretty smooth. I forgot that the tank I was running had a bottle of Techron in it, and it was near empty. Maybe when I hit the WOT and it blew that cloud of smoke out, it blew some crap off the valves or out of the injectors or fuel system. I don't know, my uncle said he had that happen one time in a honda he had, thought he blew the engine from the sound/smoke it made but it ran much better afterwards.
__________________
Old 03-27-2015, 10:09 PM
Bruners4's Avatar
Bruners4 Bruners4 is offline
Bruners4 is gaining momentum as a positive member of FTE.
I was having issues with the engine running like it had a full race cam in it and black exhaust smoke, way too much fuel. This would happen once in a while for a couple of years when first starting it up. Shutting down and restarting usually brought it back to normal. I would check codes and they just didn't make sense. After setting for a month and not being started, it did it again and would not come out of it. I couldn't get codes out of it after that and it would not perform the startup tests. Pulled the ECM and checked the caps. I had a couple of leakers and one with a broken leg. Fixed the ECM and has been running great since. Pretty easy to pull and check.
__________________
'91 F150 Supercab XLT Lariat Shortbox 4x4, 5.8L, E4OD, manual BW1356, 2.5" lift, 32x11.5x15 Falken WildPeak, 4.10 LSD F&R, Warn HD hubs.
They call me Dave
Old 03-27-2015, 10:23 PM
DattMavis's Avatar
DattMavis420
Quote:
I might give that a try this weekend while i'm working on it. My cam is stock and the smoke only happened that one time so far, but i've been seeing a lot about the capacitors failing in these trucks causing various running problems. Definitely worth a look, easy as it is to get to it.
__________________
Old Yesterday, 08:59 PM
DattMavis's Avatar
DattMavis420
Quote:
So i'm still having my running problems. Sometimes when I crank it up in the morning and it does its high idle thing for a minute or so, it will choke down after a couple of seconds. Cranks right back up, sometimes its fine, other times it bounces between 500-700 rpm. I still get the hesitation when I'm accelerating or riding at speed sometimes, but theres never a specific circumstance that seems to cause it.
I finally got around to pulling my computer. I was actually hoping for a busted capacitor, but it looks brand new in there, not even any dust.
Changed the water pump and removed a double handful of sludge from behind it, its cooling better but no difference in how it runs. fixed the exhaust too, but again, no improvements in running.
I've been thinking about the o2 sensor since i got the code for it, but could that cause the kind of problems i'm experiencing?
Also, I was working on it today and also noticed that my oil leak is worse, and I think the pan gasket is on its way out along with the seal. And theres some brown/rusty colored sediment crap coming out on the bottom of my dipstick, so whenever work slows down and I can do without the truck for a week I guess i'm going to bite the bullet and pull the engine so i can do the front and rear seals, the pan gasket, and clean out everything as best as I can. Found plenty of rust spots/patches on the frame and other parts while I was under there too, so i'm going to go at it with some rust reformer and some kind of undercoating while I've got the engine out.
__________________
Old Yesterday, 09:13 PM
anthonym92's Avatar
anthonym92 anthonym92 is offline
anthonym92 is starting off with a positive reputation.
Had the same problem and same codes. Had vacuum leak between plenum and intake manifold
Old Yesterday, 09:26 PM
DattMavis's Avatar
DattMavis420
Quote:
I'll check that out tomorrow, I've replaced all the hard vacuum lines and most of the soft ones, but as bad shape as the system was in when I started working on it, i wouldn't be surprised if I missed something.
__________________
Old Yesterday, 09:45 PM
anthonym92's Avatar
Get a can of starter fluid and spray it around the plenum. Also check for a whistling sound
Similar Threads
Truck Starts, then dies: Also dies while driving RedDevil460 1999 - 2003 7.3L Power Stroke Diesel 8 04-20-2015 07:06 PM
1990 F-150 Restoration and Mods DattMavis 1987 - 1996 F150 & Larger F-Series Trucks 3 03-31-2015 07:51 PM
at wits end, wondering if this truck is even fixable kedynskrow 1987 - 1996 F150 & Larger F-Series Trucks 16 11-11-2014 12:23 AM
starting issues jefftb 1999 - 2003 7.3L Power Stroke Diesel 16 02-14-2014 08:44 PM
93 f150 barely runs in the morning blj0hnst0n 1987 - 1996 F150 & Larger F-Series Trucks 25 07-10-2013 08:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
