1968 ford 2 to 4wd swap
Is the bronco's transfer case shift level in the floor?
What engine's do the vehicles have?
Is it possible? Yes.
I wish you luck my friend as it is no easy job.
Also, are you using the automatic transmission out of the Bronco? If not, make sure the transfer case will bolt up to whatever transmission you are using. Also, having an automatic transmission in front of a transfer case makes the transfer case so far back that you need a bracket / extension going from the lever in the cab back to the transfer case which is closer to the bed. (If that makes any sense.) If you are using the automatic transmission from the Bronco, it may have the bracket / extension already but it may not be the correct length due to the wheelbases being different. I cannot tell you for sure, and the only way you will find out is by doing it.
I do know that no 4x4s had twin I beam suspension. Why? I do not know, it may have something to do with the front end / front drive shaft. 4x4s are also factory lifted an inch or two. Im not saying you will have to do this, but a body lift may free up some necessary room you may find yourself needing. Remember, that truck was not designed to have a front drive shaft.
Like I said, keep up with your build and post some photos and questions and you will get all the help you need here in the 67-72 section.
See you around,
Mister_King
See you around,
Mister_King
thanks for the help I was going to use then bronco trans and it suck that the bronco got rolled its has 32,000 on it and was really nice I do have a highboy I was go to put the bronco stuff in it but my f100 need to come apart and ive always wanted a 4x4 f100 67-72 but ive put efi in a 88 ranger and never had a problem with it so I should be able to do it
IMo, those who ask the 2wd to 4wd question are typically ill-prepared to undertake the job.
New front x member to hold front leafs...not too bad
Locate and make holes for shackles(front leafs)...easy but make dang sure they are located right.
Custom engine x member cause 2wd aint gonna work...easy or difficult depending on your plan.
Might need engine mounts..at least sourced or modified from 4x4 truck...easy
Custom trans x member or at least relocated....difficulty unknown I made my own. Check for driveshaft clearance at trans crossmember at full bump and droop.
Might as well thrown a Redhead steering box in there along with a Borgeson shaft....should box frame and sleeve it for steering box mounting holes....due to 78-79 steering box being a bit short for 2WD frame you might have to sink it into the frame a bit.....kinda easy but dont forget it needs to clear core support.
T/C shifter and linkage..source from 4WD truck...easy
Mod floor for T/C shifter....easy
Support for T/C...easy
I wonder if the speedo cable will work????
New D shafts...it's only money. 203 transfer case and adapter will push the T/C yolk back far enough to keep front DS angles ok. Your stock setup should work ok.
Make sure the oil filter wont get whacked by the new front axle at full bump...ask me how I know. you want the oil filter mounted horizontally or relocated.
That's all I can think of right now. Good luck.
