So rear pads and rotors... What should I go with?
I am pretty sure I did the hawk green pads on my 5.4 a few years back and they seemed alright. I would like to go ahead and redo the rears and bleed the brakes while I have it all apart to try to get the pedal a little more firm but I'm not sure what would be the best. I don't tow but I do love to brake hard. I'll be doing the rotors at the same time and was planning on buying these brake rotors unless there is something better without being 3x the price. How much of a difference is there with just stepping up to the SS braided lines?
I'm going on 4 years with my Power Slot Cryo treated slotted rotors. Before i was warping stock rotor replacements every 6 months. I'm also Running HAWK sever duty parts...i love'em!
I need to do rotors and pads on the F-150 soon...thinking power stop this time around as i've heard good things?
Braided SS brake lines makes a notable difference in pedal feel. In fact, I have a 3 piece set you can have if you take care of the flat rate shipping. All you would need then is to call Crown and have them make you a set of the rear axle braided lines.
The reason my left over is 3 piece is because I bought the 3-piece Crown set and then realized it was missing the two pieces for the rear axle. So, I ordered the 5-piece Russell set just to use the 2 axle pieces. Someone here on FTE with more patience than me figured out that Crown actually makes the axle lines on special order.
For the rears, go with a quality OEM replacement like Centric. Any decent pad to match the Centric rotors will be fine.
I have Wagner pads with a set of Centric rotors that I use for the rear brakes on my rigs. Since the rear brakes provide much less stopping power, a good quality set up (ie, ya aint gotta pay an arm and a leg) is easier to find.
Stewart
Stewart
I can also put those in my shopping cart and check out tonight when the wife gets home! Thanks for the heads up Razzi!!!
