transmission slips in overdrive
As weird as it may sound, I would check your cop's (coil over plug). If you have a bad coil/s it can often make the transmission slip feeling. I believe the overdrive off changes the firing of the plugs and that is why you may be feeling the difference. I have heard several other people, including myself, have the same or similar problem.
Cracker289
08-24-2012 12:44 PM
Mach1Murph
09-02-2009 09:45 PM
kerry2u2
04-18-2003 11:07 PM
