1996 f150 4.9 clutch pedal on floor
Hey all,
Truck wintering for the last 3 months. When parked, the clutch was engaging very low to floor. Topped off fluid.
Got in today and the clutch pedal goes to floor.
Looked for bleeding instructions here, but need specific info. It looks like you can bleed w/o removing slave, but where is the bleed bolt? Any place to find pics? I'm no mechanic but think I should be able to do this, yes?
All help is greatly appreciated.
Thanks!
Thanks!
Check the side of the bell housing on driver side. Just above where the line that comes from the reservoir there should be the bleeder. You can gravity bleed it or have someone pumo the clutch and then crawl under and bleed it when they are still pushing the pedal. Best to have the bacl of the truck higher then the front when doing this, it helps remove air alittle better it seems.
Be sure to remove the rubber boot in the Master Cylinder.
I had a similar problem and I removed the bleeder screw completely. Then I saw that the screw had crud blocking the passage. I cleaned it out and then tried again. Very little, but better. Then I grabbed my handheld vacuum pump and got the fluid running. It took me several attempts, but I got it.
You might want to see if you can poke around in the hole with a small screwdriver or thin spray straw. If that doesn't work, try the vacuum approach.
I found that when I first bleed mine, that at the bottom of the reservoir, there was slime or sludge, looked metallic though. I siphoned out with a turkey baster and paper towels until all the fluid was empty and the sludge gone. Then I refilled the reservoir, and tried again. Took several attempts.
Don't get discouraged. Mine wasn't taken care of and I just slowly worked on getting it cleaned and the fluid eventually started draining. Once you get it started, it'll really start flowing out.
