water separator and wrench light on?
I was driving today and the "drain water separator" warning came on the dash. it was also followed by a wrench, and alternated between the two lights. I attempted to drain the water, but only small drops came out. I tried cleaning out the drain, no change. It has been drastically cold here the past few weeks, and i haven't used the truck much. I understand that it might be plugged up. My question is this. Can i remove the triangle cover (and unglog) without having to replace the gasket? Or can i remove the filter and clean it out, then put back the same filter? My plan in to get it to the dealer this week for filter change and oil change, but i need to drive it a couple times before then. Or does anyone else have any advice.
You can take the cover off and drain the separator, it's like a 50/50 crap shoot. I have heard of it done several times without issue, and a few times with issue. It needs to be drained, and if you can't get it to the dealer to get it serviced I'd take it off. If you don't run a fuel conditioner/ lubricant now I most certainly would get some in it right away and run a heavy mixture to get some lubricant to the fuel pump.
Back to your original post ... there is a real good chance that your wrench light came on because either your sensor failed or the sensor is clogged with paraffin. You already know you have paraffin blocking the valve, so its probably fouled the sensor too. I had to do the same repair, shortly after getting my truck, and I drove it over to the dealership, bought the parts and then drove it home and did the repair a few days later.
The fix is to: pull the fuel filter, remove the cover, clean it all out, change cover gasket, change the sensor and change both fuel filters. You could try to save yourself some money but this total job is less than $80. I'd estimate about $20 for the sensor, $50 for fuel filters and $9 for the gasket. I don't recall the exact prices but I do recall that it was a very easy job.
If it were my truck I'd be perfectly comfortable driving it over to the dealership if they are going to work on it. You have to decide how comfortable you are.
I usually do drain it once a month. the problem is i dont drive the truck enough. Especially in the winter months. I have owned this truck since june 2007, and only have 41,700 miles on it. I never had either of the warnings show on the dash. the truck gets it work out during the camping season towing our 37' fifth wheel camper.
A lot of people use their trucks same as you, part time, good way to make a vehicle last, only problem is in a diesels mind it would rather be working. Seems that doesn't matter so much for a gasser, but for some reason diesels not so much. I'm sure it will like it much more after a couple of tanks of fuel pulling the 5ver around.
bsa_bob
09-15-2011 12:58 PM
