Manual choke
Manual choke
I finally bought a Bronco (woohoo!). The guy that sold it to me pointed out the choke and told me to pull it out before starting it, then push it in. Can anyone explain this more and the reason behind it. I've never had a car with this and want to understand it. I figured you guys could help. I look forward to learning more. Thank you in advance!
A manual choke assembly (as opposed to an "automatic" one) merely requires that you, the driver, tune the choke valve during engine operation. "All the way in" (assuming the cable is properly adjusted) means that the choke valve (butterfly) is fully closed and therefore the ONLY air coming into the engine is the pre-tuned idle air set by the mixture screw(s) on the carburetor. A cold engine needs more fuel and less air so cold starts should be done with the choke mostly or all the way closed. As the engine warms up, you will begin to feel the engine fall on its face due to the high fuel volume and relatively small amount of air getting into the engine. As this occurs, you need to pull out on the handle to open the choke valve and increase the air being drawn into the engine. Hot restarts, don't necessarily require that you fully close the choke to restart the engine. As for what position works best for your engine, that is something you will have to learn by ear and feel.
Grey, you reversed IN and OUT.
Pulling the Choke handle OUT closes the choke plate for cold starting.
Once started, pushing it in about half-way is a good compromise till it warms up.
Pushing the choke handle all the way IN opens the choke completely.
that is the normal connecting up of a manual choke, and all the chokes that I saw/used back in the real old days where there was only a manual choke all worked that way.
Everything else was good
The last manual choke I had to deal with was inverted. No idea why it was that way... besides, y'all know I'm a lil' bass ackwards anyhow!
44nneedit
02-28-2018 01:43 AM
towmater
07-27-2007 12:08 PM
big hoss 29
02-18-2005 09:00 AM
