Torque Pro not reading transmission fluid temperature?
I have a 2000 7.3 F-250 with a manual ZF6 transmission. I just installed Torque Pro on my Android phone and plugged up the OBDLink MX bluetooth to the truck.
I am able to view/log everything I want, except for the one thing that I bought the OBD monitor for, the transmission temperature. I have tried all of the transmission fluid temperature (methods 1, 2, 3) PIDs under the Ford Powerstroke listing, and a couple of custom ones I found online, but nothing works.
1st attempt reads 30 degrees and does not change.
PID 221674
min/max 0/250
Equation ((A*256)+B)/8
2nd attempt reads 213 and does not change.
PID 2211bd
min/max 0/250
Equation (((A*256)+B)*-0.0036)+212.98
If you have cracked this problem that I am having, please post the fix action here. Thanks for any help you can provide.
PID 221674
min/max 0/250
PID 2211bd
min/max 0/250
I would appreciate the help in researching this. I am scouring the internet now for an answer to whether or not the PCM on the ZF6 registers temperature.
Thanks for your help, and now anyone wanting to know if the ZF6 registers temperature, they will probably run across this post and get their answer.
If you want to read the temp on the ZF-6, you have to add your own temperature probe. Ford didn't provide one for us to use.
But since we don't have a torque converter that's slipping or generating heat, it's not really that critical. I've always drained my transmission fluid every 50k miles and it always comes out looking like it did when it went in. No dark colors or burnt smell.
It's gotten my by for the last 500k miles, so I'm not too worried about tranny temps.
I just started using this today, the app will connect via Bluetooth but will never register to my truck... I wonder if the obd II sensor I picked up is just junk....
