Off idle hesitation on new carter 1 barrel??
so I went ahead and picked up a brand new carter YF 1 barrel on eBay for my '84 f150 (duraspark converted 300 six). Of course it's probably a Chinese copy, but I've been having problems with crappy rebuilds with worn out original carbs. I put the eBay carb on and it starts and idles great, cruises great, but has a nasty hesitation or flat spot when tipping into the accelerator while leaving from a stop. The idle mix has been adjusted perfectly with a vacuum gauge. I can look down the throat of the carb and I see a stream coming from the accelerator pump when I move the throttle, but it's not a very strong stream. What can I do to remedy this problem? My original worn out, leaky carter is smoother in take off than this one! Thanks for any info!
I stumbled on this link. I didn't look in there too hard, but maybe you can find something helpful.
Carter YF YFA Carburetor | Mikes Carburetor Parts
Tanntheman
07-10-2018 01:25 AM
pburress
03-20-2006 05:00 PM
Redneck-Cowboy
07-09-2003 11:36 PM
sethro
02-10-2003 11:53 PM
cjcathey2002
08-09-2002 08:04 PM
