Cloth Headliner
Cloth Headliner
So thinking about re-covering the headliner. I've seen a lot of people replace headliners with sheets and what not. I've seen a few on Craigslist that use rebel flags, or maybe it's just the same one over and over again.
So has anyone done this with the Blue interior like what I have? Been able to match the color up closely enough or not even tried? Also, was thinking of fixing the dash, so would like to find Blue Vinyl that closely matches, Or I could find a different color if it doesn't clash to bad. Have some black left over from a Motorcycle seat I did a while back. Will use that if I can't find anything else that works. It'll look better than the cracked dash on the 89.
Anyway. Off to look at a couple of parts trucks! Wish me luck!
i really haven't found anyone that says their are any differences betwen the 92-97 crew cabs and the 87-91 crew cabs. At least the basic stuff.
Well then, You'll know where the JD dealer is, and I'm right behind there, just off of 401. Been here for a couple of years. I just put in a request to join your OBS group on FB. So you should be seeing that soon. You know we do a FTE Dinner once a month right? Usually it's not too much of a haul from this area.
Nah, just peel the cloth off, take a wire brush to the old dead foam to remove it and find a local auto upholstery shop to cover it. I doubt you'd find any from Ford and if you did they'd want as much as your truck is worth or more for it.
I come through your neck of the woods on my weekly trip to Rocky Mount.
